Inexpensive occasional use bench grinder?
Anyone get any recommendation for an occasional use bench grinder? It'll mostly get used to sharpen mower blades, but I'm sure that there will be other occasional uses for it.
So, 6" or 8", HF or someone else? http://forums.pelicanparts.com/uploa...1746474800.jpg http://forums.pelicanparts.com/uploa...1746474800.jpg |
I have a 50 year old Craftsman bench grinder that I think was my Dad's fathers.
I used it a lot when we got here 30 years ago, but now I frankly only sharpen mower blades or but put on the other wheels (like buffers) for specific stuff. It is not variable speed so I can't help you there. I use it maybe 10 hours a year. Me? I'd get the 8" Bauer with the light if the reviews are good. The light really helps. |
I'm into old bench grinders.
They are twice the machines as the ones in your pictures and less than 1/2 the price. |
I have that $50 wen grinder mounted to a 2x6. I clamp it down on the bench when I need it.
I pretty much only use it to sharpen mower blades and it’s fine for that. |
I’d go HF all day long and be happy. Honestly their quality is equal or better to most big box store brands.
Since I got a Bauer harbor freight cordless angle grinder and 4 inch flap discs I don’t remember the last time I’ve used my grinder. It’s a lot easier to sharpen mower blades, chisels, etc. by putting them in my vice and using the flap discs. And those discs are cheap and seem to last forever.
If your main use is sharpening steel, a larger wheel that turns slower is your best bet to prevent overheating. 8” and 1,750 is usually considered a good grinder for sharpening.
I use an angle grinder for blade sharpening. To me, it's WAY easier than using my 8" bench grinder.
A good sharp file will sharpen a lawn mower blade better than a bench grinder with about the same time and effort.
I have a bench grinder similar to those pictured above but have only used it a few times in 10 years. I was sure I needed it when I bought it but that did not turn out to be the case. |
I used to have a small portable grinder, and never used it. My other was, I'm pretty sure an old 8" model that had a 4" sanding belt on the other side. That was nice and got used from time to time. |
I'd be looking at FB MP or Crglist for something old but local.
Lots of them at garage sales, etc that are much better then new from HF if you ask me. |
I have some ancient low quality grinder. It works great.
I would advise to check out craigslist or similar and buy one for pennies. |
Yep, mine is also an old Sears Craftsman that I use for sharpening blades, rounding off cut corners, and wire wheel to remove rust. Single speed, plenty of torque, bulletproof. They can probably be found used for $20 on FB MP.
No opinion on the new ones. |
You might get lucky on CL or FBMP and find an old Sears block grinder, for cheap, but they have a big fan club and most owners 'know what they have', so to speak.
But the big problem is that anything that I try to buy from Houston will end up being a 1-2hour drive (one way). That's what I had was some good old stuff, and I wish I still had it, but the odds of me running across it are slim to none around here. |
A bit more expensive, but if you’re just doing mower blades, something like this might be a better choice.
https://www.vevor.com/bench-grinder-c_11010/vevor-lawn-mower-blade-sharpener-2-3hp-500w-with-7-inch-ceramic-grinding-wheel-p_010770163297?adp=gmc&utm_source=google&utm_mediu m=cpc&utm_id=20922352686&ad_group=152802351250&ad_ id=687107254260&utm_term=&gad_source=1&gad_campaig nid=20922352686&gbraid=0AAAAACq8bLVfK3Zku7kBLGt4tS 5Fkzbhn&gclid=Cj0KCQjww-HABhCGARIsALLO6XxE0ATI4Yjlz6Ief-DtMu59J5y3PSYvOPFyxlNVb-xJe4qBEveW_2kaAsPkEALw_wcB |
I use an angle grinder for mower blades then finish with a flap wheel. But as for a bench grinder I fabricate and use one almost every day. I have a grinding wheel on one side and wire wheel on the other. The one i mainly use is a delta 6" I like it because its not that strong. If I get something snagged horribly it will stop. My other craftsman one is stronger and one must be more careful with it. So dont feel like you must get a big one because you might find yourself avoiding using it
My Craftsman bench grinder is at least 40 years old. I keep the stone on the right side all the time, but interchange a wire wheel or buffing wheel on the left side.
Which reminds me, lately when I turn it on, there’s a humming noise. Then the breaker trips. I have to turn it on for a few seconds and let the RPMs build up. Then turn it off. Turn on. Turn off. Repeat until the max RPMs are running and it’s all good. Would that be some kind of solenoid or ??? |
Be patient and find an old Craftsman on Craig's list or FB marketing. Save money, get a better machine. The old Craftsman square grinders have quite a cult following. People restore them like they were old cars.
I have one old bench grinder that with a fine green stone on one side for sharpening carbide lathe bits and a fine regular wheel on the other side. I have one 15 or so year old cheap Harbor Freight bench grinder with a coarse wheel on one side and a wire brush on the other. The Harbor Freight unit has very little power if one pushes hard, but it works good enough for me. I also have a Harbor Freight bench unit with extended shafts made for buffing. It works great on the rare occasion I use it. |
You sharpen chisels this way?? |
Lots of good info, folks. Thanks
1 of 2 of my Craftsman block grinders. Paid $75.00 for it.
http://forums.pelicanparts.com/uploa...1746556657.jpg |
I was thinking about trying to use my angle grinder or a manual file to sharpen my lawnmower blade a few weeks ago, since I don't have a bench grinder.
However 24$ delivered the next day for a new blade from amazon was my chosen approach. I have the disposable world we live in but here I am. Last blade went about 3 years. |
http://forums.pelicanparts.com/uploa...1746557842.jpg |
You could get a buffing pad for one side and polish them to a mirror finish! |
A note. My generic POS looks just like the Craftsman above. I paid $10 or so at a garage sale.
Deals are there. Patience. |
Mine looks like this and I’m thinking it’s from late 80s or early 90s. I bought it new. http://forums.pelicanparts.com/uploa...1746584411.jpg |
| All times are GMT -8. The time now is 09:18 AM. |
