LinkBack Thread Tools Rating: Thread Rating: 9 votes, 1.44 average.
undervalued member
juanbenae's Avatar
Asphalt Sealer
Got a quote to seal my nearly 8K SF of drive and parking area that was a solid 35% higher than what it cost me in 2021! Looking over consumer available products that have reviews that are all over the place for 4.75 gallons that range in price from $40 to $75. Since it was done 4 years ago so product should per info it should cover 400 to 500 SF per bucket since the voids have been previously filled last time.
Have any of you guys done work like this yourself and found a preferred product? I realize prep is very important so will do that accordingly going as far as pressure washing areas before application after dry time and doing it during warm weather.
What ya got for me?
Old 05-13-2025, 04:38 PM
I've done mine a couple of times. I just get the LatexIte Ultra Shield (I think that's the name) from Home Depot. I use filler on the cracks breforehand and just use a garden hose with a nozzle that puts out a good stream to clean it off. It goes down with a roller. I use about ten to twelve, 4.75 gal. buckets on a driveway (asphalt) about 145 ft. long by approx. 10 to 11 ft. wide, so each bucket covers around 150 s.f. I usually have to (should) do it about every five years or so. I have to do mine this season.
Marv Evans
'69 911E
Old 05-13-2025, 07:33 PM
(the shotguns)
berettafan's Avatar
I was so shocked at the pricing last go around. I actually looked into buying a rig for my truck and doing it as a side gig. As with paving, it is a gypsy industry.
Old 05-14-2025, 03:06 AM
Counterclockwise?
Everyone I know that has done the DYI has said never again.
Rod
1986 Carrera
2001 996TT
Old 05-14-2025, 05:46 AM
I have a 210ft U shaped asphalt drive that I was having resealed every third year.
Could have gone longer than 3 years, but the guy was only charging me $180/time.
Two years ago, he called and said the rates had gone up, but I like how it looks after a fresh reseal, so I had him do it again. He charged me $350 the next time.
I also noticed when using the gas leaf blower on it that it had lifted the edge of the coating up from the asphalt in a couple places. (about a foot square)
So I'm guessing that I have too much sealer on it....I'll cut back to every 5 years now.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 05-14-2025, 06:06 AM
(the shotguns)
berettafan's Avatar
That is my take after trying the bucket/squeegee method a few years back. Not fun.
Old 05-14-2025, 06:10 AM
The city just completed doing a slurry coat of the street down the block from us. I'm glad we got a full repaving instead of the slurry. It turned out very bumpy for riding my bike on vs the pavement that was there. It was a mixture of sand and ground up plastic bottles which had been recycled according to the guy I spoke with. I wish they had run a roller over it to smooth it out after it had set. Now, when it's been in the sun a while, people turn their wheels without moving and it tears up the surface. Not at all like asphalt.
Scott
'78 SC mit Sportomatic - Sold
Old 05-14-2025, 07:24 AM
Control Group
Tobra's Avatar
Do you need a different sealant for snow country?
Old 05-14-2025, 08:17 AM
undervalued member
juanbenae's Avatar
Not any special mix. My quad plow has rubber, adjustable wearing level pucks that keep the plow just off the surface as to not scuff or gouge up the finish.
The last guy I used owned his own tank and did paving too but has retired. The guy I'm dealing with now rents a tank and has it filled down in the valley. He is doing this as a side gig from his contracting business. He has done retaining walls and some other electrical work for me. I trust him, but water can be added to the tank of straight oil and usually is but the rate is a concern. The water makes the mix go further and helps in it curing/dry faster.
I'm concerned the over the counter stuff may not be up to the task in that it will come up when folks turn w/o moving. USPS, FedEx & UPS all go up and make a 3 point turn around in the upper area. I'm on a 1st name with the drivers and can ask them to consider this, but my gal will likely forget.....
Old 05-14-2025, 08:55 AM
Control Group
Tobra's Avatar
How much would a cement pad at the top for turning around cost? Probably way too much
Old 05-14-2025, 12:41 PM
Brew Master
cabmandone's Avatar
I asked a good friend that does this sort of thing if there was any DIY product that is worth a damn. He said "don't waste the money". He's an upfront guy that I'd trust.
Nick
Old 05-14-2025, 01:12 PM
undervalued member
juanbenae's Avatar
The pavement is only about 7 years old & in great shape so removing it for concrete is not money well spent at this point. A neighbor has a concrete slope down to his place and grooved the concrete like you would see on a boat ramp. It's actually counterproductive cause you can't plow the snow out of the grooves, then it freezes and becomes a sheet of ice, in the shade no less. Concrete does hold up better than asphalt with snow chains though.
Ya, as I mentioned I figured the off the shelf stuff was less effective, especially being susceptible to unraveling in the scuffing turn areas. I read a bunch of product reviews that did not instill a ton of confidence. If it was less SF I might be more willing to give it a try. Thanks for asking your buddy.
Old 05-14-2025, 03:34 PM
Control Group
Tobra's Avatar
Sounds like this is a pay the man situation
Interesting that ice gets promoted by grooved pavement, makes sense if you think about it I guess
Old 05-17-2025, 05:21 AM
I did mine - 5k sf. Wasn’t that bad. Prep was a pain, but the actual job wasn’t awful. Saved a couple k over having it done for me.
It's been 3 years and it held up just fine. I’ll be redoing it this summer.
Old 05-18-2025, 03:57 PM
undervalued member
juanbenae's Avatar
What product did you use, and do you have much in the way of turns? Specific turns that the uninformed will turn while not moving?
Old 05-19-2025, 01:06 PM
If diy...count on wrecking a pair of pants and shoes.
98 Honda Prelude
22 Honda Civic SI
Old 05-20-2025, 12:47 PM
undervalued member
juanbenae's Avatar
Did some bid shopping and found a guy that was only $300 more than when I had it done 3 years ago. Ended up his wife came to be his helper, and I knew here from the local Liquor store... Gotta love that small town Mayberry stuff.... Watched every bucket go down and brushed in with a very thick spread rate. Very happy with the results and will keep traffic off it for 3-4 days.
Gunna be an expensive few days if that boat purchase goes through later this week.
Old 07-28-2025, 03:48 PM
peppy's Avatar
I have done our parking lot at the restaurant about twice, 35 years ago was the last time. I used a sealer form southern states that had creosote in it and it burnt my ass up. The first time I did it I had no issues with the burning.
I have convinced myself that it's just cosmetic and save the money.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 07-28-2025, 04:29 PM
Wow, that looks great!
Is it really as smooth as it looks in the pics?
Scott
Old 07-28-2025, 04:55 PM
Information Overloader
Let me just say, ‘Never again.’
The cost to have it done was too close to what I paid for materials alone. Guy’s scheduled to do it tomorrow AM.
Old 07-28-2025, 05:24 PM
