Any chemists here?
I've been doing a lot of electroless nickel work and now the partner company would like it to have a slight gold tone to it. None of my platers will even entertain the question but I'm wondering if another metal or substance could be added to the nickel bath that would colorize, even just slightly, the resulting plating.
I've also looked in PVD to replace nickel but that has it's own limitations.
Tru6 Restoration & Design |
Cue in the R&D for a product that financially probably won’t pay off.
As a chemiker (that has not reviewed literature on this topic), i would attack this problem with doping (Co, Sn, Cu, etc). Lots of variables and would inspect the work with XRF and/or SEM w/EDS … remember, micro before scale up.
dolor et pavor Copyright |
Control Group
I thought you plated the gold over the nickel
She was the kindest person I ever met |
I don’t think they want to pay for the use of actual gold…?
One of my favorite rxn’s is to electroless deposition pennys with zinc and heat them up.
Just need a hint of gold tinted nickel. So not gold, just the idea of gold.
Hi
A lot of the nickel plating that I have seen had a straw / pale yellow color. For nickel plating colors including, white, gray gold and black, see more here: https://www.electroplatingmachines.com/news/common-colors-of-nickel-plating.html Cheers Last edited by Magyar Kiwi; 05-22-2025 at 11:25 AM.. |
Not quite what you’re asking about, but does require some chemistry skills.
![]() ![]() ![]() [img]http://forums.pelicanparts.com/uploads26/100000811217478941 ![]() [img]http://forums.pelicanparts.com/uploads26/10000118151747894423.j
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Sent thread to a couple of the chem instructors at work....
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
I see you
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
