-   -   Need help from the brain trust again (http://forums.pelicanparts.com/off-topic-discussions/1178178-need-help-brain-trust-again.html)
wdfifteen 05-23-2025 02:10 PM
I'm trying to fix my trailer lights and can't get the taillights to work.
Flashers work OK on both sides.
Voltage at the taillight connector on the flat 4 at the back of the truck fluctuates all over the place. I plug the connector in and get the same weird voltage fluctuation at the trailer taillight unit. Truck taillights working fine. It's a 2017 Tundra with factory trailer wiring.
On another note, I made the mistake of putting new, cheapie light units on the trailer years ago. They are still bright and shiny inside, but they grab the bulb with such a death grip that getting the bulb out destroys it. Arghhhhh!!
1990C4S 05-24-2025 05:34 AM
Check the grounds. And buy a plug in tester.
GH85Carrera 05-24-2025 05:55 AM
This. The majority of electrical issues on cars and other items is a poor or just bad ground.
dad911 05-24-2025 05:58 AM
Does the voltage fluctuate with or without the trailer connected?
As above, I keep a plug-in tester in my tow vehicle. They are cheap. Also, IMHO, it's better to test with a test light than a voltmeter. It puts a small load on it, and you only really need to know on/off.
I'd also swap those 'cheapy lights' for leds.
afterburn 549 05-24-2025 06:54 AM
Yup grounds.
Go to the plug at tow vehicle and see if you have power there . Check brake lights etc.
If you do, it is the ground.
BK911 05-24-2025 07:42 AM
Just went through this on my 2017 Titan.
Turned out to be a couple of fuses in the truck.
wdfifteen 05-24-2025 12:47 PM
Originally Posted by dad911 (Post 12470171)
Does the voltage fluctuate with or without the trailer connected? .
Both. I get the same behavior at the trailer light unit as at the flat 4.
wdfifteen 05-24-2025 12:50 PM
This. I’m suspecting it’s something in the truck. I tested the trailer with a 12 volt mower battery and roach clip leads and the trailer lights work fine.
