wdfifteen's Avatar
Need help from the brain trust again
I'm trying to fix my trailer lights and can't get the taillights to work.
Flashers work OK on both sides.
Voltage at the taillight connector on the flat 4 at the back of the truck fluctuates all over the place. I plug the connector in and get the same weird voltage fluctuation at the trailer taillight unit. Truck taillights working fine. It's a 2017 Tundra with factory trailer wiring.
On another note, I made the mistake of putting new, cheapie light units on the trailer years ago. They are still bright and shiny inside, but they grab the bulb with such a death grip that getting the bulb out destroys it. Arghhhhh!!
Old 05-23-2025, 02:10 PM
Check the grounds. And buy a plug in tester.
Old 05-24-2025, 05:34 AM
This. The majority of electrical issues on cars and other items is a poor or just bad ground.
Old 05-24-2025, 05:55 AM
Platinum Member
dad911's Avatar
Does the voltage fluctuate with or without the trailer connected?
As above, I keep a plug-in tester in my tow vehicle. They are cheap. Also, IMHO, it's better to test with a test light than a voltmeter. It puts a small load on it, and you only really need to know on/off.
I'd also swap those 'cheapy lights' for leds.
Old 05-24-2025, 05:58 AM
Air Medal or two
afterburn 549's Avatar
Yup grounds.
Go to the plug at tow vehicle and see if you have power there . Check brake lights etc.
If you do, it is the ground.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-24-2025, 06:54 AM
Home of the Whopper
Just went through this on my 2017 Titan.
Turned out to be a couple of fuses in the truck.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-24-2025, 07:42 AM
wdfifteen's Avatar
Originally Posted by dad911 View Post
Does the voltage fluctuate with or without the trailer connected? .
Both. I get the same behavior at the trailer light unit as at the flat 4.
Old 05-24-2025, 12:47 PM
wdfifteen's Avatar
This. I’m suspecting it’s something in the truck. I tested the trailer with a 12 volt mower battery and roach clip leads and the trailer lights work fine.
Old 05-24-2025, 12:50 PM
