-   -   A question re a lawn tractor (http://forums.pelicanparts.com/off-topic-discussions/1179237-question-re-lawn-tractor.html)
Crowbob 06-21-2025 12:33 PM
Plus, a hot air balloon is landing on your property!
Run over there! The tradition is for the balloon pilot to gift a bottle of Champaign to the land-owner of where he lands.
stevej37 06-21-2025 12:42 PM
Haven't heard of any balloon...
Rice wine?
I only own a little over one acre....he won't have much room to land.
Crowbob 06-21-2025 12:45 PM
In the pic! It’s in the pic!
stevej37 06-21-2025 12:53 PM
Oh...I gotcha!
I'm a little slow today...biking and mowing in the 80's
https://forums.pelicanparts.com/off-topic-discussions/1178763-new-type-wind-spinner.html
That thing startles me every morning when looking out the window. It has a 5ft streaming spinner ribbon at the bottom and it appears to be a snake with any wind.:)
Crowbob 06-21-2025 12:54 PM
Oh.
Nevermind.
masraum 06-21-2025 01:08 PM
You just clearly need to get rid of the PITA JD and get a zero turn where all of this maintenance crap is a lot easier!
I guess the only downside would be if your tractor has PTO and you have various attachments other than just mowing. Don't you have a vacuum for the leaves? I don't know that would be an option on a ZT. But maintenance on them is super easy including removing the deck if you want/need (usually just easier to put it into wheelie position and slide under it)
stevej37 06-21-2025 01:14 PM
This JD has served me well. It has power steering, cruise control, and a very comfortable seat. :)
I bought it new 22? years ago for $7200
My only other lawn tractor I've owned was a JD 317....not bad, 2 tractors in 50 years.:D
Yes, I pull a Trac Vac in the fall for leaves and grass. (the TracVac has a Honda engine)
LEAKYSEALS951 06-21-2025 01:59 PM
You guys are FOUR pages into this?
http://forums.pelicanparts.com/uploa...1750539529.jpg
Crowbob 06-21-2025 02:02 PM
And?
Crowbob 06-21-2025 02:05 PM
I simply cannot abide by the single function of a ZT when I can get 10 attachments (so far) for my tractor and struggle with all kinds of machines instead of just one.
stevej37 06-21-2025 02:10 PM
^^^ Plus they have to use two hands for steering....ridiculous.
stevej37 06-21-2025 02:12 PM
Originally Posted by LEAKYSEALS951 (Post 12485093)
Now that looks safe...if I remember to leave the Carrera in gear.
Crowbob 06-21-2025 02:13 PM
http://forums.pelicanparts.com/uploa...1750540276.jpg
LEAKYSEALS951 06-21-2025 02:53 PM
http://forums.pelicanparts.com/uploa...1750541969.JPG
http://forums.pelicanparts.com/uploa...1750542004.JPG
Bonus points if you use the lift!
This thread got me thinking. I've got a 728, which is a compact tractor wannabee, and even with the deck removed from the frame, I get the heebeejeebees lifting even the deck like that to attend to the blades. Double goes for the side pull behind.
Although I think the front end is more than strong enough to be lifted like that, even at the front axle/frame pivot, I don't like getting my own mug under such things. Specially when you are trying to tighten the deck blade volts and the top is swaying in the breeze from dangling.
All day, I've been thinking of the HF ramps which are plenty to hold the tractor, and I've been thinking it would be cool to make some inboard ramps parallel to the car lift ramps for the width of the tractor-
But then I wondered if you took one of the HF ramps, and mounted it perpendicular to the 'lead in' on the car lift, bolted in place upside down (like I pictured my ramps), and drove the front tractor wheels into the HF ramp- it would catch the front wheels and lift would raise the front end just like the strap. Would have to be in neutral though, and would want to strap the front wheels down into the HF ramp.
I would still probably do the inboard ramp thingee like others said though. Might not be as good access with the ramps running between you and the blades, but at least for me, less heebeejeebees.
The perpendicular HF ramp would be a heck of a lot more stable than the pulley thing though. I hate doing the pulley strap myself so much I usually put off sharpening blades way longer than I should. Cleaning the deck? fudgettabouttitt~!
stevej37 06-21-2025 03:21 PM
^^^ I think the front beam of the lift would interfere with the deck when trying that. Lifting it might damage the leading edge of the deck.
I sharpen the mower blades every third time now. The lawn looks better than ever.
Tobra 06-21-2025 03:34 PM
Originally Posted by stevej37 (Post 12484928)
^^^ I'm not picturing that as helping when I use the lift for car maintenance.
It would be in the way for the Carrera when changing oil.
Maybe I'm looking at what you're saying wrong....need a pic.
You purchase a second set of tracks, secure with screws to crossmember
Stand the second set of tracks in the corner when the Deere is not on the lift
Alternatively, you could drill holes to bolt the existing tracks at a width appropriate for a lawn tractor
If it were me, I would make something out of PVC angled such that I could power wash the bottom of it without bending over with the tractor sitting on the ground.
LEAKYSEALS951 06-21-2025 03:40 PM
Clearly the only solution is to mount two ramps over the turtle pond. powerwash it there.
Turtles get fresh water and grass. Mower clean. problem solved.
stevej37 06-21-2025 03:41 PM
I bought an Amazon pvc under deck washer that would spray up a few years back.
It was worthless to me....maybe my water pressure is not enough?
stevej37 06-21-2025 03:46 PM
They are too spoiled to appreciate grass...it's freeze dried shrimp or turtle pellets.
Nothing else. :)
dad911 06-21-2025 04:06 PM
Wow guys, talk about beating a dead horse.
Who's got the pic of a racecar suspended by the tie-downs after the trailer flipped?
