Retired Member
Brian 162's Avatar
Originally Posted by rfuerst911sc View Post
Dad911 how does the composite hold up to outdoor furniture being dragged across it ? Like chairs at a table , you have to drag the chair out , sit in it and then drag yourself forward to be at the table . The reason I haven't gone composite is the horror stories of scratching the surface , water getting in and then it swells and looks like crap .
We have furniture, gas bbq, and a propane fire table. We drag the furniture and move the fire table. No scratches and we get lots of afternoon sun and the colour hasn’t faded
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 06-28-2025, 06:08 PM
Prices of different products vary of course. Like everything else, you get what you pay for. The more expensive stuff looks better. I would recommend a raised grain product. It looks way more real and is less slippery when wet
Old 06-28-2025, 06:11 PM
Leadfoot Geezer
rcooled's Avatar
Something to be aware of...rain water will remain on the surface of a composite deck longer than on natural wood.
I always frame joists 12" on center for composite...
I used TimberTech composite decking with raised grain that has the look of natural wood. And yes, joists on 12" centers for stability. Makes the deck feel very solid when walking on it...like walking on concrete.
Not my deck, but this is what I used ↓
'13 BMW 335i coupe - current DD
Old 06-28-2025, 07:06 PM
Platinum Member
dad911's Avatar
I've built several composite decks and there are many clip systems. They have improved greatly over the years. If you're attaching a fascia board to a perimeter face, clips won't work. Use matching colored screws and not finish nails as they will only hold so long due to expansion and contraction. Don't ask me how I discovered this fact :^)
IDK if available for all manufacturers, but for borders, steps and fascia (and azek house trim) we use the screws with color matching plugs(search cortex plug).
Old 06-28-2025, 10:56 PM
beepbeep's Avatar
I put in composite 3 years ago. Still looks fine. It needs 2x support beams compared to wood though.
Thank you for your time,
Old 06-29-2025, 12:45 AM
Driver, not Mechanic
Trex!
Old 06-29-2025, 08:15 AM
Thanks for all your responses. I will be doing the install myself so every bit of advise is very helpful. I've done plenty of wood work but my tools are a bit limited at the cabin.
The supplier told me that composite expands lengthwise quite a bit so how tight should the butt joints be? The deck is 32' long so I can use two 16' lengths and have one seam down the middle (that's what I did with the original cedar) or I can offset the seams by alternating runs of one 16' and two 8' lengths with a run of two 16' lengths. Bear in mind that my joists are on 16" centers.
As to the costs: I was quoted $65.92 2 x 6 x 16 cedar ($4200 total), $41.44 for a Fiberon board ($2600) and $36.10 for Trex ($2300). Both prices for the composites are for their entry level products. The prices change daily so the quote was only good for 3 days!
Thanks again for the input.
Old 06-29-2025, 09:42 AM
Platinum Member
dad911's Avatar
I would put a board perpendicular down the middle instead of lining up joints and use 2-16' boards. Then you have no but joints. You'll just need to add blocking to the one bay.
(not my deck, pic from online)
We also border the decks so you don't see endgrain. Or hide ends with a fascia board.
If you use the clips like I showed above, the boards can expand and contract.
Old 06-29-2025, 10:34 AM
Location: behind the redwood curtain, (humboldt county) california
I've done a few decks over the years and have a few suggestions:
1) Stagger your end joints, AND add an additional joist at the joints. so that two boards don't land on one joist, (which requires screws or nails very close to the end of the boards, which encourages splitting at the ends and moisture intrusion/rot. So install two joists, about 3-4 inches apart at the ends. This also helps the life of the PT framing.
2) Textured decking is particularly important, where the deck is on the north side, or heavily shaded, which might allow moisture to stand and encourage moss/mildew to form - making things dangerously slippery. Surfaced wood can be treacherous when wet.
3) I think the concealed fastening systems are worth a serious consideration, for appearance and ease of installation. some of the surface installed screws can strip out the heads, making installation and or removal difficult.
4) The later version of TREX, with the improved surface layer seems to be fine on 16 inch joist spacing, compared to the old version, significantly more colorfast, textured and stronger.
chris
Old 06-29-2025, 11:03 AM
^ I think you mean add blocking between the joists at the butt joints.
I would double up the joists for composite. 16" on center seems fine at first but in the heat of the summer those boards turn to noodles and you have a wash board road.
Chalk line to start and check again for straightness every 4'
Old 06-29-2025, 01:03 PM
MAGA
Tim Hancock's Avatar
I just ripped off our old deck boards and replaced with Deckorator brand composite boards from Lowes. They were 16' and I only needed 14' I bought 25 of them for around $30 each. Old deck boards were treated 2 x 4. Joists were on 24" centers so I added new joists in between. I used the plastic hidden T universal fasteners from Lowes. I did not do the picture framing technique and instead bought and stained treated 5/4 deck boards for fascia to cover the ends. I went with 1/4" gaps everywhere. Looks pretty good. Just need to finish up the landscaping and build a new pergola/lean to roof over it. It is a bit slick when wet but wife is happy so.... win.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 06-30-2025, 07:17 AM
Counterclockwise?
Has composite come down in price from a few years ago?
Rod
1986 Carrera
2001 996TT
Old 06-30-2025, 09:28 AM
MAGA
I got about the cheapest stuff I could for my little 12 x 14' deck above. It was about $1000 for the the deck board and fasteners (not including my 7 new 2 x 8 PT joists, hangars, 5/4 fascia boards and stain). I thought that was pretty expensive for a crappy little deck. That said, some other brands of composite decking was nearly double.
Wife wanted composite so that is what she got.
I can't even imagine how much some folks are paying for large fancy multi level composite decks these days. Traditional 5/4 deck boards with fasteners would have cost me maybe half or slightly less.
0% Liberal
Old 06-30-2025, 11:03 AM
rfuerst911sc's Avatar
^^^ Tim do the hidden fasteners provide the gap between boards ? Or did you have to do something extra to provide the gap ?
Old 06-30-2025, 02:21 PM
Reg Reg is online now
Reg's Avatar
I’ve been in building supply business all my life. Yes I’m partial to wood but let me tell you that none of the composite stuff will look like new in 15 yrs. Everything has pros and its cons.
My deck is red cedar faces south and naturally gone grey and with that I have close to zero maintenance.
I face nailed it on with galvanized spiral finish nails and when time to replace peel them off and repeat.
Old 06-30-2025, 04:11 PM
Retired Member
Brian 162's Avatar
Originally Posted by Brian 162 View Post
We have a composite deck that came with the house. We like it, no maintenance required. After 3 winters of heavy snow it still looks good. The only negative is when the sun hits the deck in the summer the deck gets hot. You can’t walk on it barefoot.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 06-30-2025, 06:12 PM
MAGA
Yes, the fasteners are 1/4" thick and space the boards.
https://www.lowes.com/pd/Trex-Universal-200-sq-ft-Coverage-Black-Clip-Hidden-Fasteners-360-Count/1001364364
0% Liberal
Old 07-01-2025, 03:58 AM
I like to put some innovation into all my work so I really want to try the composite but I don't think I'll be able to. All the framing is based on lumber 5 1/2" (5 3/4 " gapped) widths, the composite I'd be using (Fiberon) is just 5 3/16" (5 3/8" gapped). That 3/8" gapped difference over 25 - 30 boards screws everything up. 5 1/2" composite is available from a different manufacturer (Trex) but the colors are brutal. The offset design of the deck with one half being 16" deep and the other only 12' deep also complicates the retrofit.
I'll keep trying to come up with a solution for the composite but right now it looks like I'm stuck with cedar.
Here's what it looks like now.
Old 07-01-2025, 08:35 AM
Composite decking will work just fine. Double up your joists and cap them all with paper. Add lots of blocking and maybe sister on a rim joist if needed at the end. Check the health of the existing joists at the house with a screwdriver, they look suspect. I would also add a beam across the middle while it's open. It'll feel way more solid
Old 07-01-2025, 08:51 AM
Platinum Member
dad911's Avatar
Originally Posted by 5495bb View Post
I like to put some innovation into all my work so I really want to try the composite but I don't think I'll be able to. All the framing is based on lumber 5 1/2" (5 3/4 " gapped) widths, the composite I'd be using (Fiberon) is just 5 3/16" (5 3/8" gapped). ........
Don't overthink the board width, start on the outside and put a rip by the house if needed.
This.
While the decking is off, it would be a good idea to make sure grade pitches away from the house, and maybe put down some plastic and stone.
Old 07-01-2025, 09:04 AM
