-   -   Dealing with a stump without having it ground out. (http://forums.pelicanparts.com/off-topic-discussions/1180408-dealing-stump-without-having-ground-out.html)
Tim Hancock 08-07-2025 06:44 AM
I burned out several stumps a few years ago by simply tossing firewood logs onto them for a couple days. I did not use a can around them although that would have been nice. Every couple hours I would blast them with a leaf blower to get them glowing hot then toss on some more logs. I kept this up over a weekend and got them burnt down to just below grade. Other than my time, this cost me nothing.
Bill Douglas 08-07-2025 12:53 PM
On the farm as a 10 year old boy I was highly pissed of with my mother for not letting me buy explosives from the farm supply store. We had some pretty big stumps that needed blowing up and I was just the guy to do it.
stevej37 08-07-2025 01:27 PM
Originally Posted by Tobra (Post 12510977)
I like todrill some holes in the stump and turn it into a rocket stove.
Zero chance of an underground fire here
Same here....rock hard Michigan clay dirt doesn't burn too well.:)
gacook 08-07-2025 01:34 PM
Burning the stump is my go-to method. Works great.
stevej37 08-07-2025 02:58 PM
Originally Posted by masraum (Post 12510848)
No rain in the forecast for the next week+. Every day 5-25%, so probably safe for a bit. I'll probably be able to reuse the flashing from 2 that I'm burning now on the two that are left. I'll buy another bag of charcoal and be good to go.
Still burning? How's the progress?
masraum 08-07-2025 03:14 PM
Yep, still going and is working really well. I should have used more charcoal on the biggest stump and done the smaller stumps later. The biggest stump is probably 6-8" below grade, except there was one spot where the trunk had a root that sticking out to the side where I didn't have charcoal (the plan was to spread the charcoal over to that spot, but I clearly forgot), and that point is still proud of the ground level. I took the coals from the two small trunks and from the center of the still very hot big trunk and stacked them up on that spot, so I suspect that by tomorrow or the next day that spot will be good. The two smaller trunks are good. In the future, I'll use a bit more charcoal. I've got one or two more trunks to burn. The key seems to be to use enough charcoal to cover the top of the trunks.
stevej37 08-07-2025 03:28 PM
^^^ Great!...Let her burn!
I almost had a path in my lawn checking on the fire before the rain came. Sure beats swinging an axe. :)
