Dealing with a stump without having it ground out.
Last year, I had a tree taken down and asked them to cut it as close to the ground as possible. It was close to the fence line on the edge of a field, so I thought I would just drive over it with my JD. They left it about 6 inches high and impossible to drive over.
I decided to use Stump-Out. The stump measured 6' 7" in circumference. I had some 10" flashing that I cut to 7' long and made a small barrel around it. I used my Bauer 10" battery chain saw to score the top in multiple lines. Poured the Stump-Out in, added water, and let it set for 6 weeks. Last Wed., I added a couple layers of Kingsford to the top and 'lit er up'. It burned for 3 days and then rain came. http://forums.pelicanparts.com/uploa...1752869293.jpg http://forums.pelicanparts.com/uploa...1752869328.jpg http://forums.pelicanparts.com/uploa...1752869376.jpg http://forums.pelicanparts.com/uploa...1752869410.jpg |
http://forums.pelicanparts.com/uploa...1752869521.jpg
6 bags of topsoil added http://forums.pelicanparts.com/uploa...1752869561.jpg Grass seed and straw added and watered. http://forums.pelicanparts.com/uploa...1752869588.jpg |
Nice!
Good thinking on using the fire to burn it out after you killed it. |
Nice work!
Don’t be surprised, if you need to add additional dirt, as the stump decays. |
^^^ If it hadn't rained...I'm sure it would smoking and smoldering yet.
But I didn't need that...it did it's job. The fire left the outer bark...I think the heat couldn't get to it good. So I used my Bauer to cut that off...which went easy. |
Thanks Yeah, I am kinda counting on that. At least I can mow over that area again. (after the grass seed takes off) |
If you go the same route with the 'Stump-Out'....be aware that you might need two of them.
The one pound can doesn't go far. |
Brilliant solution. I have a bunch of stumps at the family farm. Too bad I can't buy dynamite anymore...
^^^ Pmax
My place is on a hill and there are three lakes within a half mile and one is a mile long. Not much worry of fire here. |
I know...I remember going with my G'pa to buy sticks when I was a kid. Buy them at the hardware in town...and then go to a shed in an isolated area to get the dyno. It was an easy way to clear a field. |
Excellent! Nice job.
I had a big tree removed from my yard recently. The removal service did the same thing only they drilled about a dozen holes deep into the stump and soaked it in diesel fuel for a couple days before adding the coals and lighting it.
Nice job ... reminds me of Great Grandpaw Stumpy and country engine-ears :) |
I tried that with my 20V battery drill...it got very hot before I could even do one hole. The stump was about 200 feet from an outlet, so my corded drill was out. . |
Anything that saves me from trimming around it is worth it.:) I use pramitol around each fence post, but to do that around the stump would make a large dead area. |
Yer either lazee or smart ....
Or both :)! |
Another option although slower is use Epsom salt . Drill some holes in top of stump . Pour the salt in the holes and on top of the stump . Cover with a pile of leaves . This method speeds up the natural decay/rot .
Thanks for sharing this. I have some stumps on my property that need removed so I can mow. I will give this a try.
Before I used the stump out, I tried my sharpened axe to see if I could chip off enough of the outside top of the stump to give a gradual rise for the mower.
I don't do it often, but I know how to swing an axe. That dried surface of a few years dead elm is like concrete. If the axe doesn't hit it square...it just ricochets off. I gave up with that after a dozen swings. :) . |
| All times are GMT -8. The time now is 06:46 PM. |
