Brakes creaking when at rest?
So, I was bleeding my brakes today with the car in the air when I noticed that the front end of the car was creaking when I was applying the brake pedal to check that the pressure was good. I couldn't pin down where it was coming from, but the noise was relative to the position and force of the brake pedal.
With the bleeder valves open, there was no noise. Is this normal or am I about to die? |
Sounds like!
Squeaky wheel gets the grease.....
My knees do that.
Squeaky brake fluid. Buy the good stuff.
The rears on my Tundra squeaked/groaned. I jacked it up and tried to rotate a tire and i could barely turn it. Took the left caliper and pads out and it turned freely. Both rotors had rust. The pad’s contact patch on the outside was 1 1/2 inch and inside was 3/4” due to the rust, so I had the pads and rotors replaced. No more funny noises! |
Not sure if that would cause squeaking. |
Somehow I managed to put this in the OT instead of the 911 forum. Great job, me!
I'll repost to make sure, but thanks for the input. I'm going to check and grease the pins this weekend, as well as enlist my wife to pinpoint the source of the noise. |
Where is Steve with a post titled "Bones creaking when rest" or maybe "rakes creaking when test"?
Which Steve?
I like "Bones breaking when I rest." |
| All times are GMT -8. The time now is 11:05 AM. |
