Banned
Brakes creaking when at rest?
So, I was bleeding my brakes today with the car in the air when I noticed that the front end of the car was creaking when I was applying the brake pedal to check that the pressure was good. I couldn't pin down where it was coming from, but the noise was relative to the position and force of the brake pedal.
With the bleeder valves open, there was no noise.
Is this normal or am I about to die?
Old 08-07-2025, 01:08 PM
Banned
Originally Posted by Arizona_928 View Post
Did you grease the slide pins/rails?
Spring '23 when I had new pads and rebuilt the calipers, but not today.
Old 08-07-2025, 01:15 PM
Banned
Sounds like!
Old 08-07-2025, 01:26 PM
unsafe at any speed
wswartzwel's Avatar
Squeaky wheel gets the grease.....
Bill Swartzwelder
Old 08-07-2025, 01:29 PM
My knees do that.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 08-07-2025, 01:34 PM
Edministrator
Steve Carlton's Avatar
Squeaky brake fluid. Buy the good stuff.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 08-07-2025, 01:50 PM
wdfifteen's Avatar
LOL!
The rears on my Tundra squeaked/groaned. I jacked it up and tried to rotate a tire and i could barely turn it. Took the left caliper and pads out and it turned freely. Both rotors had rust. The pad’s contact patch on the outside was 1 1/2 inch and inside was 3/4” due to the rust, so I had the pads and rotors replaced. No more funny noises!
Old 08-07-2025, 02:05 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I have mentiond this before and you probably know but there is a bleeder on the proportioning valve near the shock tower on the left side on (most?) Toyota trucks.
1981 911SC Targa
Old 08-07-2025, 02:39 PM
Bob Kontak's Avatar
Asian cars in the rust belt rust in the channel where the stainless inserts fits causing a pinch on the pad tangs/tongues/protrusions. Pads can freeze in place from getting squeezed.
Not sure if that would cause squeaking.
1981 911SC Targa
Old 08-07-2025, 02:45 PM
Banned
Somehow I managed to put this in the OT instead of the 911 forum. Great job, me!
I'll repost to make sure, but thanks for the input. I'm going to check and grease the pins this weekend, as well as enlist my wife to pinpoint the source of the noise.
Old 08-08-2025, 05:29 AM
Where is Steve with a post titled "Bones creaking when rest" or maybe "rakes creaking when test"?
Old 08-08-2025, 05:32 AM
Edministrator
Which Steve?
I like "Bones breaking when I rest."
O - $1
O - $2
O - $3
Old 08-08-2025, 05:57 AM
