Team California
speeder's Avatar
Cool motor but how does one remove the oil filters without making a mess? Lots of rags at the base, I guess.
There would be zero oil in the filter at oil change time with that design. Least messy filter removal out there.
This is assuming that you're smart enough to let the engine/car sit for a little while after shutting it off.
Denis
Old 09-08-2025, 10:19 AM
Make Bruins Great Again
Por_sha911's Avatar
I air cooled 911 uses only 'aftermarket' Mahle oil filters.
Joe
Old 09-08-2025, 10:50 AM
Team California
speeder's Avatar
I wrote a long post about auto parts and the parts business but must have gotten distracted before hitting “send.” The cliff notes version is that the consumable parts that you buy from the dealer parts counter are inferior to the ones put on your car at the factory. There are different tiers for even name brand parts.
I’ve told the story here before about my friend with an indy MB shop that only uses dealer parts. He realized a long time ago that replacement brake pads never last as long as the original ones on cars that he services exclusively. It’s a marked difference and impossible not to notice.
I have a 2022 Chevy Malibu that I use for Uber and it has 64k miles as of today with the original pads and rotors nowhere near needing replacement. At the current rate, it might be at 100k. I don’t ride my brakes and I’m pretty smooth behind the wheel but still…can’t believe it. I wear out brakes in normal time on everything else.
As far as filters go, there is just no reason on earth to use crap. OEM or even dealer filters are usually cheap. In some cases, like the fuel filter for my Power Stroke diesel, the dealer or OEM filter has patented features wrt where it touches the bypass valve that makes it impossible for an aftermarket filter to be the same.
Old 09-08-2025, 11:12 AM
Por_sha911's Avatar
Just what I said yesterday:
Originally Posted by Por_sha911 View Post
Different quality standards:
OE is original equipment - meaning parts are what went on the vehicle when manufactured.
OEM is original equipment manufacturer - meaning that company supplies parts to the manufacturer for a new vehicle BUT that doesn't mean that the parts on the FLAPS shelf are the same as the one when the vehicle was built. They can be vastly different in design or quality.
Joe
Old 09-08-2025, 11:28 AM
Team California
speeder's Avatar
I’m or talking about parts from FLAPs, I’m talking about parts from the dealer’s parts department that are different from what came on the vehicle originally.
I’m well aware of the difference between OEM, OE, all of that ****. It goes deeper than that.
Old 09-08-2025, 12:19 PM
Model Citizen
herr_oberst's Avatar
I wonder if Fram's are better than those old JC Whitney filter canisters that used a roll of toilet paper as filter medium....
Maybe Project farm will test them.
Old 09-08-2025, 12:39 PM
^^^ My first car was a 66 Chevelle with a 283 that had the cannister oil filter holder. Put any brand in and go.
The first oil change I did myself, I didn't dig out the gasket and when I replaced the filter it doubled up. I stopped at a store and a guy shouted at me.."You've got oil leaking like crazy!'
I had lost most of it, replaced the gasket, filled it up, and went on.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 09-08-2025, 12:56 PM
Reg Reg is online now
Reg's Avatar
I had a machinist work for me for 9 yrs. Before me he spent 28 yrs at a plant dedicated to making Fram (and oem) filters. One of the best employee we ever had.
Old 09-08-2025, 03:38 PM
A930Rocket's Avatar
….This is assuming that you're smart enough to let the engine/car sit for a little while after shutting it off.
Now see, that’s where the problem starts….🤪
Old 09-08-2025, 05:33 PM
Counterclockwise?
I bought a filter for my wife's Corolla last week from the dealer and it was around $10.00.
Why mess with it?
Rod
1986 Carrera
2001 996TT
Old 09-09-2025, 06:54 AM
E Sully's Avatar
To those who have seen Lake Speed Jr's videos, this one is interesting regarding filters. The main part is about him making a custom oil for his Boxter. The filter part is towards the end at 17:45 where he gets into the difference between high mileage and regular filters.
He discusses that in order to make high mileage filters work with the less frequent changes, they are less efficient than the standard filters.
Lake also is against any more than 5,000 miles between changes and uses WIX in his car.
https://youtu.be/ppjFvzwN4Oo?si=Tez1S1rJJbvpmBlr
Ed
1973.5 T
Old 09-10-2025, 06:44 AM
Picked up some fresh oil and a new filter for the Silverado. It's oil still looks pretty good but I will probably change it anyway in a week or so. I really like this "oil in a box"!
$22.98 for the oil and $4.16 for the filter....not bad!
Old 10-01-2025, 04:05 PM
Arizona_928's Avatar
I’m for less plastic waste and have bought the cardboard boxed oil. The valves leak a a little and i just kept the box right side up with the valve facing up.
dolor et pavor
Copyright
Old 10-02-2025, 08:00 AM
Isn't the parent company filing Chapter 11?
Brent
Old 10-02-2025, 10:41 AM
Grip It & Rip It
edgemar's Avatar
$8 Purolator Boss on Amazon!
82 911SC (sold)
Old 10-02-2025, 11:00 AM
Zeke's Avatar
That's a whole 'nother ball game. The TP filters used a significant bypass. I would guess they filtered 10% of the oil, if that, on each full exchange of the 5 qt's or whatever your vehicle required. The TP did remove particulate and water. That was a bonus. What was not so good was 90% of your oil was being recirculated with a random 10% being filtered unless your retained the stock filter. Some did not because the kit required you to remove the filter canister.
I realize that a normal filter has a bypass and the oil that goes through it is a random selection if the bypass opens. Turns out, some engines have a by pass in the block. (Porsche, IIRC), those that don't rely on a filter that does. The delta is about 10 lbs. differential from OP going in vs. OP coming out. A clogged filter will have a larger differential letting more oil bypass. Remember hot oil has less pressure so that can drop the delta.
Does every engine and filter send 100% of the oil through the filter and oil cooler, if equipped? I guess you need to know your car or engine driven equipment. Do some filters allow more oil flow and thus less differential? You bet.
Old 10-02-2025, 11:13 AM
Yep
Old 10-02-2025, 11:47 AM
