From what you described, the chain needs to be tightened a bit. Chain stretch wouldn't normally cause it to jump off the chain ring. I imagent when you go over a bump, you foot is at 3 and 9 o'clock acting as shock absorber, meaning no force or turning on the pedals therefor chain bounces off the chain ring. Another place often over looked is the chain ring bolts. Tighten them up a bit. Maybe one or two had come loose.
before you lube the chain, check every link is free and not stiff.
That causes shifting issues and it may even be the cause of chain jumping off the ring. |
Yes, my feet are at that position to give equal absorption of the bumps. I could try it at noon and six and see if that makes a diff. I'll be on the same route tomorrow. I will check the chain before lubing it, and ring bolts....I don't notice any noise from the chain or sprockets when pedaling. (other than normal) Thanks for the help.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 09-22-2025 at 06:56 PM.. |
^^^ I switched the seat post shortly after I bought the bike for a shock absorbing one.
Made a big difference for the expansion joints on the road. My back can't take sharp bumps, I had back surgery a year ago. I'll check that hangar bolt.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
You'd think that having a decal on the side of the bike saying 7S...I would know there is no 8th speed. It must be dementia.
Remove 3-5 lbs off your tires. It makes a HUGE difference with the sharp jolts.
You do not have permissi
(you DO carry carry a chain-splitter tool, air pump, patch kit, tools, just checking) And there is a way to measure derailleur spring back-tension of course. The next question would be check lateral run-out of gears. Warped disks. They can tweek L/R but they should not. Not compared to knees. Like a saw blade.
Meanwhile other things are still happening. Last edited by john70t; 09-22-2025 at 10:14 PM.. |
weekend wOrrier
This video at about 2:30 shows what happens when a derailleur gets stretched too much. I was betting his chain was too long- this is a way to see if it is, and if you can get by with removing 2 links- when he simulated it, the deraulleur got pulled straight / overextended, so removing 2 links was not an option for him. I ff'd to the exact section: Assuming you cannot remove 2 links in the largest cog - as simulated in the video(what you call "1"), then you are either looking at a stretched chain or a b adjustment as a fix, or a combo of both. take a screwdriver on the next ride, find a pothole that jumps it, tighten the b screw 1/2 turn or two, remember what you did, see if that fixes the jump on the spot. If not, or the shifting stops working well- loosen b adjuster by same amount, go home and buy new chain. This is all after you have: Checked chain for kinks/ tight links Checked front chainring for bent teeth (side to side) Lubed Chain That bike also has a lot of corrosion on it. Make sure there is : No slop/looseness in crank bearings No slop/looseness in reab hub Last edited by LEAKYSEALS951; 09-23-2025 at 03:05 AM.. |
Raining today, might be afternoon or tomorrow before I take it out.
I'll check the tire pressure...I believe I have them at 60 psi now. What you're seeing in the pic is dirt/mud...no corrosion. It's only a year old. After I clean it and lube the chain, I'll take another pic.
Checked the 5 crank bolts...all were tight
Set the tire pressure to 50psi. Tire sidewall calls for 50-75 psi. Lubed the chain good....can hear nothing now when turning the crank on the bike stand! I can see no slop/looseness in any of the drive parts. When the roads dry, I'll take it out. Don't care for the wet skunk stripe up my back.
Oops...forgot the pics after cleaning and lubing.
weekend wOrrier
Hey Steve- sorry to keep blowin up your thread, but what kind of bike/model (what year) is that? (For better or worse- I've got time to kill....
)The bike seems to be built to look like a single speed type esthetic with the rims and the front chainring, but usually on bikes like that, I think of chain guard ring protector stuff. That bike doesn't have one. Not necessarily bad, they might have left it off for the single speed "look"- but I'd expect to see a guard on something like that bike as stock. Something like this- ![]() bike is looking good clean! Last edited by LEAKYSEALS951; 09-23-2025 at 05:59 AM.. |
weekend wOrrier
Looking good.
I swear that setup might just be able to subtract 2 links and work. Maybe.... Maybe not ![]() Here's another video on determining chain length from scratch. I'd swear your chain looks longer than the cog to cog +2 method mentioned in this video: I would guess if you ran the chain from large rear cog (what you call 1) to front chainring without the derailleur, like he does, you'd have at least 2-4 extra links Last edited by LEAKYSEALS951; 09-23-2025 at 06:04 AM.. |
Hey...no problem, I love talking about bikes. I learn something new each time. I have three bikes, this one is a Propella, pedal assist bike that I use mostly when I know I'm headed for hills or a windy day. It must be pedaled or it won't go anywhere. My bike I use for rails to trails is an 8 speed (I think that's why I was mixed up last night) belt driven Vilano. Perfect bike for stopping and starting often. No need to downshift before stopping.....just thumb it down while stopped to 1st or 2nd and take off. There's a recent thread on here...I'll look for a link. My third bike is a 24 speed Vilano road bike. I lent that out a few weeks back. I don't like riding that one so much because of my back. The Propella in the pics is one year old...I had a duplicate that was two years old and it was stolen off of my Swagman bike rack last year. ![]() I have the Garmin Varia on the Propella to make road riding safer. I was hit broad-side 7 years ago and had to have a titanium rod put in my broken femur. Some reading if you want....https://forums.pelicanparts.com/off-topic-discussions/957058-anyone-else-have-done-their-leg.html Be sure to read the linked article in my first post. That's exactly what they did. .
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 09-23-2025 at 06:46 AM.. |
They make a device that clamps to the seat post that won’t allow the chain to fall off. It’s called a chain keeper or catcher. Some of the pros even use them when using one chain ring to prevent chain drop. I think chain drop is somewhat common even on a well set up bike.
Rutager West 1977 911S Targa Chocolate Brown |
^^^ Everytime it's happened to me, it's caught/wedged between the pedal arm and chain ring. (and the rear of the chain stays on the gear it was in)
Easy to slip back on and hand turn the crank to get it seated....just messy. It's also never happened to me while normal riding....just when hitting big bumps. That's something I'm going to need to avoid or slow down more around them.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 09-23-2025 at 07:00 AM.. |
Here you go Steve, keep those fingers clean by waxing your chain instead!
Waxing Bicycle Chains I’m a couple years into doing it and I love it, I can run my hands over my chain and my hand stays clean. Bike doesn’t get covered in oily film and I never have to use degreaser on my bike.
Steve,
What about getting a cheap clamp n front derailleur that just stays in place so the chain can’t fall off either side? You might have to get creative on getting it locked down in the right spot- they have limit screws which might have enough range.
