What are these things?
I saw these online, and the place that I saw them, they were trying to figure out what they were. I suspect someone here will know.
Ayo Irpin, Ukraine!
Peg and socket inserts I think but, for what material?? Wood?
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
This seems to be what these are. Male and female alignment pins/sockets which is, I think, basically what you said.
multiple random response to the original thread below. Quote:
Platinum Member
IDK, but this is what AI says. Is it correct?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
disband
Jets of some sort? To make a pressurized fluid a mist?
Really cool, can't wait to find out what they do.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Ayo Irpin, Ukraine!
Hmmm.
I have dowel centering tooling for aligning hole centers for drilling. These are the type where you have the pilot marked or drilled one side then the discs center and mark the other board when clamped together. ![]() Original items look like they’re meant to press fit and stay so, I don’t see them being used for patterning. Do look like they’re probably for table leaves though I’ve only ever seen wood dowels on leaves. Guess bougie tables might have used brass.
I think they are things that (back in the 80's) you drilled and stuck the blunt end into the bottom of your stereo speakers. It was so the sharp end got a good grip on the floor to stop movement.
Ayo Irpin, Ukraine!
Ha! Speaker spikes for better bass response!
![]() Actually my Klipsch SW10 sub has spikes installed from the factory with plastic foot covers if you don’t want holes in your hardwood floors.
On a hunch I Googled “brass butt plug.” (I mean, why not?) There is such a thing, but Google took me down a rabbit hole (no pun intended). Apparently, someone makes a “Stainless Steel Dual Taco Holder Butt Plug.” I kid you not. Look it up.
Fleabit peanut monkey
Here are gun cleaning jags - random pics. I say no as subject parts are uniform in size and the tapered screw end is not used on cleaning rods. Just standard machine threads. Edit: The tapered ridges are not threads. Meant to be pounded into something
https://www.google.com/search?client=firefox-b-1-d&sca_esv=d306f2ba7f45299a&sxsrf=AE3TifNG9wKEuLwm9ptdlGvzLvHaIdXf9A:176143380 3906&udm=2&fbs=AIIjpHxU7SXXniUZfeShr2fp4giZ1Y6MJ25_tmWITc7uy4 KIeioyp3OhN11EY0n5qfq-zENwnGygERInUV_0g0XKeHGJRAdFPaX_SSIJt7xYUfpm-_vQHq3hzHA2DKyn4_QBnQl9QSPW8ISHQ0OitRg6rbhOiAHpaPY Kwp8XXwkiDWCehsUuFXgyLBupLnleqhU8CTuwFaD9RIZ6lrPal VfJZgukZQ7Ljg&q=gun+cleaning+jags&sa=X&ved=2ahUKEwjwl7WhvMCQAxXWv4kEHY5RFQkQtKgLegQIERAB&biw=1920&bih=927&dpr=1
1981 911SC Targa Last edited by Bob Kontak; 10-25-2025 at 04:27 PM.. |
1981 911SC Targa |
Parrothead member
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Edministrator
lol
Good post? Leave a tip! O - $1 O - $2 O - $3 |
