Salary increase tactics
Have you guys ever used a tactful negotiation technique that has successfully secured a pay increase? Mind sharing with us your success?
TKS
1989 911 3.2 1990 964 3.6 |
I've found explosives could play a positive role. That and incriminating photos of the boss and his secretary. In these days of Photoshop, the latter is easier and not as messy.
Binge User
When I worked for private industry, I often found the only way to get a raise was to put in my two week notice. That usually works & if not I would go get another job.
Paul |
Somewhere in the Midwest
Leave the company...a new job should bring 10-20%. Try getting 20% at the same job.
and don't forget to always be seen with the little red book
Richard 87 Targa 20 LS 500 |
likes to left foot brake.
If you have a higher salery offer at another job your present employer may match it, call it a fair market salery adjustment.
Hell with the salary increase - give me stock options
Free minder
Hell with the salary increase - give me more vacations
Time is more precious than money... Aurel |
Free minder
You could use your vacactions to work yourself on the Porsche, and you will save on the maintenance bills
...Otherwise, Las Vegas ...or, if you want to bump up your salary, working more or negociating will only give a linear increase, within a usually predetermined range. If you are already at the top of the range, and not paid at the comission, there is little room for more. Unfortunately, the degree seems to be more significant to the salary than the performance. For instance, a bad phD will usually make more than a good engineer...so, if you want a quantum jump in salary, I would recommend getting a higher degree. First thing is to honestly assess if you are underpaid or overpaid for what you are doing.Aurel |
Unless the company is large and with many technical goals having a PhD on payroll does not make sense. You hire these folks out on a temp basis (winning contracts, writing proposals) cause they create too large of a hit based on cost vs. performance over the longer haul. I've worked with a fair number of these types and their egos are difficult to manage and frankly, they aren't all that productive. Nothing gets under their skin more than having a guy with a BS from San Diego State lead them. Haha! Last edited by dmoolenaar; 10-22-2003 at 06:18 AM.. |
