Remember the many holes (windows) an airplane has?
As an architect, we are familiar with structural components which have many holes, such as airplanes with their many windows. They are none the less strong for the "holes".
Wheel are similar. Strength is not reduced, if the holes are "engineered" correctly (as the airplane windows are).
The reason that wheel manufacturers do this, is to avoid stocking many different wheels with many different bolts centers and sizes. Note that some companies design over-size holes, then require you to use washers to make the holes bolt-centric.
But your concern is well-founded; such wheels can't be as "good" as ones made specifically for your car, your bolt pattern, your hub-centric condition. And generally they weigh much more, too.
1983 911SC Chocolate Kiss (Smokey Quartz Metallic)
1991 VFR750F
1982 VF750S
Miata (wife's)
Audi A6 Quattro (family)
Old 04-02-2004, 07:23 AM
Me like track days
Craig 930 RS's Avatar
Then there were the airplane windows of the DeHaviland Comet jet of the mid-1950s.........a MAJOR structural failure in this area caused these promising planes to be grounded. Square windows just did not work - too many stress risers.
Craig
@RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-02-2004, 07:32 AM
304065's Avatar
Ahh the DeHaviland comet. . . square windows, to crack at the corners with every pressurization/depressurization cycle, and no-bypass turbojets located in the wing root, so when you lose a compressor blade, you slice through the main wing spar! Ever wonder why modern jets have the engine so far ahead of the wing leading edge? It ain't aerodynamics or weight reduction!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-02-2004, 07:40 AM
B58/732
BlueSkyJaunte's Avatar
The Comet may have been a deathtrap but it sure was beautiful.
ΜΟΛΩΝ ΛΑΒΕ
Old 04-02-2004, 08:01 AM
IROC's Avatar
Holes (windows) in an aircraft and holes in a wheel are two different things. In an aircraft, the windows are holes in a pressure vessel. If you do the math, there is a huge amount of force pressing outward on the skin of an aircraft once you get above 8-10000ft.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-02-2004, 08:53 AM
304065's Avatar
'81 R65
Old 04-02-2004, 08:58 AM
Early_S_Man's Avatar
Hey, John! Ever see the 1951 Jimmie Stewart movie 'No Highway in the Sky' ??? A bit of Hollywood mumbo-jumbo about nuclear fission in aluminum atoms ... but, nevertheless, a predictor of metal fatigue as a major problem in jets ... a couple of years before the Comets started falling out of the sky! Makes you wonder if a disgruntled De Haviland employee wasn't a factor in the screenplay?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-02-2004, 09:18 AM
Light,Nimble,Uncivilized
Re: Remember the many holes (windows) an airplane has?
Ah, ever seen the inside of a modern day fuselage without the interior bits? There is a lot of reinforcement (and extra weight) around those windows. Generally the fuselage is much stronger and can take more cycles (landings and takeoffs, with pressurization) without the windows. Take a good look at a OEM designed and built cargo plane...no windows.
Drago
'69 Coupe
R #464
Old 04-02-2004, 09:26 AM
Me like track days
I was a Boeing 737 engineer for 14 years. Without windows, a fuselage
is a remarkably simple structure:
Stringers (looong U-shaped pieces which run fore and aft)
Stringer clips (which hold the stringers to the fuselage ribs)
Ribs (circular/circumferential pieces at every body station - vertical pieces)
The window areas are a PITA to machine and design. Holes in a fuselage do not help an aircraft ;-)
Left Boeing to start my own Porsche business.
Craig
@RS
Old 04-02-2004, 09:54 AM
304065's Avatar
It would be better, in my opinion, to have LCD screens where the windows are, with external cameras, to provide "synthetic vision" to the passengers. You could pan, zoom, IR to shoot through clouds/precip, and auto-dim the screens.
'81 R65
Old 04-02-2004, 10:00 AM
Virginia Rocks!
VaSteve's Avatar
You know I had this same idea for the interior cabins on cruise ships. If we got together we wouldn't have to drive these old beat up Porsches, we could buy new ones!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-02-2004, 10:03 AM
Senior Member
john_colasante's Avatar
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 04-02-2004, 10:07 AM
Put the LCD screens in the arm rests, make them so they fold out on articulating arms and you've got it...oh wait, they already have that...only in 1st class though
Drago
'69 Coupe
R #464
Old 04-02-2004, 10:23 AM
You do not have permissi
john70t's Avatar
This definitly belongs in O.T. but is way-interesting.
The stuctural integrity of a piece of a hollow tubular frame during a varied vibrational cycle.
[edit:I wasen't making too much sence when I typed this. Sorry]
Old 04-02-2004, 11:30 AM
Hey now! This is a family site!
Old 04-02-2004, 12:54 PM
Super Jenius
Overpaid Slacker's Avatar
Send a message via AIM to Overpaid Slacker
Warren -
I've seen that freaking movie. I think I was nursing a post-overserved condition one afternoon and it was on AMC. Goofy film.
In a prior life I did some naval architecture, and the rule is never a square corner -- all the stress "focuses" on corners and the failures are often spectactular and w/o warning. Coaming helps some, but you're specifically designing in failure point if you add a corner.
JP
2003 SuperCharged Frontier ../.. 1979 930 ../.. 1989 BMW 325iX ../.. 1988 BMW M5 ../.. 1973 BMW 2002 ../..1969 Alfa Boattail Spyder ../.. 1961 Morris Mini Cooper ../..2002 Aprilia RSV Mille ../.. 1985 Moto Guzzi LMIII cafe ../.. 2005 Kawasaki Brute Force 750
Old 04-02-2004, 01:23 PM
304065's Avatar
Comet Crashes due to fuselage breakup
G-ALYP 10 January 1954 35 Fatal
G-ALYY 08 April 1954 21 Fatal
If you look at the other crashes, more than two were caused by stalling the aircraft (overrotation). So in addition to round windows, it sounds like the Comet needed a stickshaker also.
'81 R65
Old 04-02-2004, 01:42 PM
Retired in Georgia
Robert Coats's Avatar
Son-of-Comet!
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems?
-Robert Coats
Old 04-02-2004, 04:32 PM
Maybe we could go on an LCD vacation too... It's a nice idea, but i dont think itll provide quite the same effect.
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 04-02-2004, 06:15 PM
