 OT - '91 Volvo problem Parents came for turkey day visit.  My father owns a '91 740 volvo.  When warm, idle is dropping and almost stalling.  If you accelerate quickly from a stop it stumbles but when you are very gentle on the pedal, it accelerates normally.  At speed, car appears to run fine.  When cold symptoms do not exist.  Car is 4 cylinder fuel injected. I am thinking vacuum leak. What is best way to check? Any trouble shooting ideas appreciated. I can't find any info elsewhere and you guys are a great resource. And if I don't get this fixed soon, my parents may never leave.... Chris |
 I have been working on a '90 740 for a while now. Brickboard is very helpful. http://www.brickboard.com/FAQ/700-900/ Known problems with that model are Fuel pressure regulator RPM sensor Dirty injectors and throttle body Misadjusted or malfuctioning throttle position sensor Fuel pump and filter Fuel pump relay |
 On my Saab and a number of other Saab owners that I've spoken to, a problem such as you describe turned out to be the Idle Air Control  (IAC) valve.  It usually doesn't have to be replaced, just removed and cleaned with carb cleaner. Steve |
| All times are GMT -8. The time now is 01:11 PM. |
