| Registered |
				OT - '91 Volvo problem
			Parents came for turkey day visit.  My father owns a '91 740 volvo.  When warm, idle is dropping and almost stalling.  If you accelerate quickly from a stop it stumbles but when you are very gentle on the pedal, it accelerates normally.  At speed, car appears to run fine.  When cold symptoms do not exist.  Car is 4 cylinder fuel injected. I am thinking vacuum leak. What is best way to check? Any trouble shooting ideas appreciated. I can't find any info elsewhere and you guys are a great resource. And if I don't get this fixed soon, my parents may never leave.... Chris
				__________________ Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie | ||
|  11-26-2004, 09:38 AM |
| Moderator |
				__________________ Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne | ||
|  11-26-2004, 10:38 AM |
| Registered |
			I have been working on a '90 740 for a while now. Brickboard is very helpful. http://www.brickboard.com/FAQ/700-900/ Known problems with that model are Fuel pressure regulator RPM sensor Dirty injectors and throttle body Misadjusted or malfuctioning throttle position sensor Fuel pump and filter Fuel pump relay
				__________________ Randy '87 911 Targa '17 Macan GTS | ||
|  11-26-2004, 01:41 PM |
| Registered Join Date: Jan 2004 Location: Chicago, IL
			On my Saab and a number of other Saab owners that I've spoken to, a problem such as you describe turned out to be the Idle Air Control  (IAC) valve.  It usually doesn't have to be replaced, just removed and cleaned with carb cleaner. Steve
				__________________ '82 911 SC | ||
|  11-26-2004, 02:14 PM |
