bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Anyone use hibernate?
I know this is a stretch, but I know there are a few programmers here...
I'm having a hell of a time getting a query from a many-to-many relationship... I basically want to select all of the beans of one type that aren't part of the many-to-many relationship. I could do it easily in SQL, but Hibernate's HQL syntax is pretty funky. I'm thinking I need to map the collection or something... any ideas?
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 02-10-2005, 05:50 PM
Cars & Coffee Killer
legion's Avatar
Man...never heard of that product...I use good ol' DB2. What operating system/hardware does that run on?
5 liters of VVT fury now
-Chris
Old 02-11-2005, 05:43 AM
I believe it will be run on the Apple XServe (http://www.apple.com/xserve/) but for now it's running on my g5. It *could* run on anything running Tomcat and any sort of database.
I ended up figuring it out about 11:45 last night... I can't believe it took ten freaking hours to figure out one query string. Works swell, though
Old 02-11-2005, 07:12 AM
id10t's Avatar
How is OS X for a server? My gruv.org server is an iMac, but I have it running on Debian Linux instead of OS X... I'm guessing for my uses I'd have to do a lot of setup work for fink and darwin to get all the utilities, etc. I use...
Old 02-11-2005, 07:39 AM
I like it a lot. It's not a lot different than using a linux server, and if you get into the command-line stuff, it's very similiar. If you use OS X and not OS X Server, there's a pretty big difference, as far as utilities and monitoring go. Any utilities that you use have probably been made for X also, or there are alternatives.
Since our project is JSP/Java and we're using CVS, it really could be done on a Linux box just as easily.
Old 02-11-2005, 07:46 AM
