Norton Ghost
Anyone here use it? Just got v9.0 and am having issues with XP. I know there are some known SP2 related problems, but I thought I addressed them prior to install. I'm getting a "cannot connect to agent, service not running" error.
I feel lost anymore, I used to have a solid understanding of older dos/windows a million years ago, but since the registry came along, I have not kept up and am lost today.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
Slackerous Maximus
What is it that you are trying to do? Image the XP box and store the image on a server? Need more details.
The firewall on XP could be causing a problem, but again, it depends on what you are attempting to do.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Yes, I just want to create an image and keep it on another drive. I think doing that is not a problem, but I can't get Ghost to run, I get this error as soon as I try and launch the program. I'm going to uninstall and try to install it all again tonight.
Man I though this was about an old motorcycle!
steve old rocket inguneer |
Senior Member
Every version of ghost I have used is used from a dos boot.
78 Euro 911sc Targa 03 Hayden SCWDP |
Slackerous Maximus
Ghost is typically used with a boot disk. You boot the computer from the disk, run the ghost executable and create an image. This image can be place on either a network server, or a second harddrive in the same computer. As far as I know, you cannot image a disk partition with a running OS on it. The contents of the partition would change during the imaging process, making the image file worthless.
Is there some sort of utility for creating a bootdisk?
From what I have learned, ghost v9.0 runs from within windows and must be "installed", all prior versions ran from DOS. From what I am learning, there are lots of issues with 9.0 (especially with SP2 - what else is new), the older DOS versions seem to be better, but this is what I am stuck with.
This is what I thought too, but version 9.0 supports "hot" imaging...actually that's all it does. Seems risky to me, but then again, I don't really know what I'm doing
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma Last edited by Paul T; 08-02-2005 at 01:01 PM.. |
Slackerous Maximus
I have not done a client side roll out in quite a while, so I should probably not continue blathering on exposing my ignorance......but that has never stopped me before. ![]() Isn't it possible to install Ghost so that it creates a seperate boot partition that allows you to create an image locally, skipping the boot disk altogether? Perhaps thats whats going on..... I dunno. I have turned into such a prima donna, I don't deploy to often...
least common denominator
We use ghost 9.0 here and I have had very few problems BUT
1. I am running it on a Win2000 OS 2. I backup to a separate drive i.e. I hook up drive to be imaged as a slave, image it to the C: drive. Then if that drive crashes at some later date, I grab a new drive around the same size, re-image it, and away we go. Seems I tried to run ghost on a Win98 and got the same errors you are getting. There is some weird work around but I don't remember it because I don't have to use it.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
I use ghost at work and at home
at work i image to a ghost cast server (that i run on one of my PCs when i need it) or to a drive mapping. both places i allways do it from a boot disk (home and sometimes work) or a boot cd (work). the boot cd has all the drivers for all of the network cards in my office, cd drivers incase i want to load from an image from a cd and ghost. works every time and i have win 95, 98, 2000 and XPsp2. i have tinkered with the ghost agent but i don't need to do it enough to justify the overhead of allways running it.
Saintly '97 318Ti Sport, DASC, H&R coil overs (sold) '07 F800ST '10 Forester X Special Edition |
Well, I guess I should have tried this first: I uninstalled and reinstalled again and everything works fine. Thanks for the replys..
