911Velocity's Avatar
67 vette BB vert to 540CI/675HP monster
I was asked to start this thread to chronicle the changeover of my original 67 BB vert to a 540CI/675 Hp Shafiroff ultrastreet 5 spd trans monster daily driver. I will update after Carlisle, probably Monday. See 911 technical thread "I drove a z06" for initial statements.
Best regards,
Gerry
Gerry
84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette
06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd
65 Chev Nova 385 Race, 85 Chevy Rollback
97 Ford Exp. EB, 90, 91 Toy PU
Old 08-23-2005, 09:55 PM
pwd72s's Avatar
So, no mods to make this swap? Meaning a regular bolt-in, not much problem returning to "original" when/if you choose to?
Old 08-23-2005, 10:31 PM
Unfair and Unbalanced
Mule's Avatar
Location: From the misty mountains to the bayou country
675 hp is a mild BB. It should be very streetable with good driveability. Trans & rear end should not be an issue. Tell us about the plans. Carb or FI? Tremec? Suspension?
Sounds like a fun car.
"SARAH'S INSIDE Obama's head!!!! He doesn't know whether to defacate or wind his watch!!!!" ~ Dennis Miller!
Old 08-24-2005, 04:33 AM
67 vette BB to 540
There is no such thing as a no problem hot rod swap but there was no cutting or things done that can't be put back to original status. I don't think I would be the one to do that, probably one of my heirs or if prices go to atrostupid levels.
The trans is a keisler TKO 600 5 spd with .64 5th , HP driveshaft and HP clutch package. The engine is the shafiroff 540 ultrastreet (Mighty demon 950 cfm carb) check out their website at www.shafiroff.com for details. The rear end still has to be completed. I have carbon fiber halfshafts, racing struts, HD offset trailing arms, 420 Lb monospring, Bilstein autocross shocks, Aluminum cross fram bushings, driveshaft and halfshaft loops, HD cover, spicer u-joints. Need upper six link kit, ultra HD ring and pinion, HD side yokes, bigger wheels and drag radials. Perhaps a full 12 bolt set of guts for the IRS would be better or better yet a ford 9 ", I heard someone is making this setup.
Right now this car is awesome [B] but excellent drivability. Your grandmother could drive it, if she could push the clutch, and she didn't put her foot in it. If you do then you have to shift NOW. Really, it just melts the tires, going to need work to get it to hook even OK. Still it scares the hell out of everyone. Lots of FUN.
Drive it like you stole it,
Gerry
PS will post pics after Carlisle.
Gerry
Old 08-25-2005, 09:50 AM
pwd72s's Avatar
Dunno about others here, but I'd like to see 'em...
Old 08-25-2005, 09:26 PM
Just for you pwd72s
Gerry
Old 08-31-2005, 05:19 PM
