curlesw's Avatar
Setting up a network using Windows XP
A question for you computer guys, I have two computers, one a desktop, one a laptop, both running Windows XP. I’d like to be able to access one computer from the other. I used the Network wizard but can only share a single folder between computers. How do I set it up so that I can access the entire computer from the other computer? Note, the computers are connected to a Linksys router for internet access. TIA.
v/r
Wayne C.
Old 09-09-2005, 01:08 PM
Slackerous Maximus
HardDrive's Avatar
To connect both computers, you need 'file and print' services running on both. You can use a wizard to start this or manually start the server serivce using the Computer Managment console. If I understand what you have done thus far, it should already be started. You will also need to configure your windows firewall to allow file and print services.
I am in insanely busy at the moment, but if you can wait until tonight I can give you step by step instructions.....
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 09-09-2005, 01:16 PM
curlesw's Avatar
All I can do now is access the shared folder on each computer...that's it. I want to be access the entire computer from the other computer. The network wizard seems to set it up to share a single folder and printer...not to allow access to the enitre computer...what am I missing?
thanks.
Wayne
Old 09-09-2005, 01:49 PM
Senior Member
Wayne,
Have you shared the drives on both computers? Unless you open the drives open to share with another computer they will not see each others drives.
Right click on the start button, left click on "explore" on both computers. Find the "C" drive and right click on it, and left click on "sharing" and make sure that the drives are shared.
Try it then... might have to reboot...
Joe
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 09-09-2005, 02:04 PM
curlesw's Avatar
No, I have not done that...I'll give it a try, thanks.
Wayne
Old 09-09-2005, 03:11 PM
The Unsettler
stomachmonkey's Avatar
Slow down Sanchez.
Both are connected to a Linksys router.
Is it a wireless router?
If so, assuming you have not done so already I STRONGLY suggest that you
a) Hide the network
b) Encrypt the access
BEFORE you go sharing your computers with your neighbors or worse.
Scott
"I want my two dollars"
"Brandon Won"
Old 09-09-2005, 05:02 PM
Senior Member
Scott,
Have to relate a story I just was involved with. Spent a while trying to get my Tivo and a wireless network to talk together so I could copy my videos to my computer and burn them to DVD to save.
Called Tivo and they said "just open up the Netgear wifi system and it will work fine" but when I questioned them about security they could care less. All they wanted is for the Tivo to work.
Good points and I assumed that Wayne had already secured the system using the WEP 128 encription. Better that way...
JoeA
Old 09-09-2005, 05:13 PM
