Need wireless home network security advice
How do you secure your network at home? I noticed that I'm picking up two other networks while sitting in my dining room. Do you use a third party software like Norton Internet Security or are there settings in IE options I should use? Thanks.
Edministrator
I came across this today, and plan on implementing it myself...
http://www.sfgate.com/cgi-bin/article.cgi?file=/c/a/2005/03/14/BUG39BO6J51.DTL
Good post? Leave a tip! O - $1 O - $2 O - $3 |
You want to do it on your wireless router. If your hardware supports it, use WPA (not wep), if not, use WEP wtih a complex key. Turn off broadcasting your SSID. If you only use one or two wireless devices, lock down your router to only accept connections from their MAC addresses.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Cars & Coffee Killer
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Picking up other networks doesn't mean YOUR network is compromised. It just means the other networks are broadcasting (and possibly not secured). You already have WEP/WAP enabled and restricted access by MAC address. Just monitor regularly and don't worry - be aware.
In a area where there are lots of wireless routers in use, all you need to do is be the least easiest system to crack. IE: If someone else is running an unprotected network near you, and you're network is protected, chances are that other network will be hacked - not yours. -Z-man.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Virginia Rocks!
How exactly do you hack into someone's computer using their wireless? I don't know enough of how this stuff works to know how people could get in....
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Chris, what's your wireless router? Chances are it will have its security software and management control panel built in.
We use a belkin pre-N router for the office and it has great security/controls... all browser based.
Tru6 Restoration & Design |
-Z.
Senior Member
Steve,
I travel for a living. Recently went to Chicago and the WiFi in the hotel was not working. I fired up the laptop and did a search and found no less than 6 WiFi networks in the area. Logged onto one of them that was not secured and downloaded my emails. I am not a hacker but if I need access and there is a WiFi network around that is not secured I will use it. Most times its another hotel or business who has not secured their system. If someone wants to get into another company or persons computer, if they have a unsecured WiFi network, thats a backdoor for a hacker. All of my WiFi system is secured with WEP 128 encription but many people just take the unit out of the box, plug it in and start using it. The default password for most of them is "1234" and the hackers know this. Its listed on the support website for all of the routers/switch's firms and if someone has not changed the info its easy to get in. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
One thing to be careful of using other peoples connections is that they can sniff your traffic. And things like POP3 and IMAP mail send usernames/passwords in plain text.
When I use an "open" wireless - hotel, someone elses neighbors, etc - I just ssh to my home machine and tunnel everything over that encrypted connection. Cheap man's way of having a VPN.
I've never understood this hacking thing. Using a network connection is very different from seeing files on anothers computer, right?
I have a hard enough time sharing files between W2K and WXP machines... And I know the passwords. Does anyone know how to hack into another machine (assuming the entire system isn't opened to share with no passwords enabled)? Is it as easy as the security people like to make it sound (in order to get you to buy a product)? - Skip
1972 911T 1972 911E "RSR" |
turn off ssid broadcast, no password, mac address specific. Or use ssh keys.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Like he said, use WPA if your equipment supports it. WEP can be hacked by anyone with some easily downloaded tools and directions from the internet in less than 15 minutes regardless of how complex the key is. Also, turning off your SSID broadcast doesn't slow someone down that wants to get on your network. It will only make it more difficult for you to get on. Setting your network up so that only your MAC address can get on will also not keep anyone down. They will just spoof your MAC which is easy to find. There are two things to consider here. Are you worried about someone around you or their teenage kid hacking into your network to see what they can do or are you worried about your neighbor ending up using your network connection? If it's the second then some of these other steps will help with that, but they won't do anything for the local hoodlum that is trying to see if he can get your stuff. For some really good info on the latest in wireless security check here http://blogs.zdnet.com/Ou/ more specifically, go to page 3 and 4 http://blogs.zdnet.com/Ou/index.php?paged=3 http://blogs.zdnet.com/Ou/index.php?paged=4
No WEP encryption is enough, regardless of the size of the key
http://blogs.zdnet.com/Ou/?p=60 Quote:
