Certified Pre-Owned
BGCarrera32's Avatar
Need Windows XP help...
2 issues...
Did a clean install of XP wiping off the old Win2000 OS and data.
Loaded XP with service pack 2, downloaded all critical updates from Microsoft.
#1) Have a user account set up for both my wife and I. When I hit start> log off> switch user> get to the user screen, select icon for the other user, machine reboots.
#2) When screen saver of any kind is active, the screen saver will come after "X" minutes, run fine, as soon as I touch the mouse or press a key, machine reboots.
I am running Kaspersky Anti-Virus; system is free of virus/spamware etc.
I think I have a driver issue. Any thoughts?
-BG
'84 Carrera Coupe
Old 10-04-2005, 12:34 PM
layzee's Avatar
I'd agree with your diagnosis. Try upgrading graphics drivers first.
Phil Garner
'72 911E Sporto
Sportomatic.org
Old 10-04-2005, 12:42 PM
Cars & Coffee Killer
legion's Avatar
Does it boot in safe mode?
5 liters of VVT fury now
-Chris
Old 10-04-2005, 12:43 PM
Certified Pre-Owned
When it reboots, it reboots just like if you hit the reset button on the box itself...
I can boot into safe mode if I want...
'84 Carrera Coupe
Old 10-04-2005, 06:26 PM
Make Bruins Great Again
Por_sha911's Avatar
Try disabling the anti-virus, reboot the computer, and try some of the things that cause problems to see if it still reboots on its own. Question: did you format the harddrive before you installed?
Joe
Old 10-04-2005, 09:20 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
I'd definitely try updating your video driver. Check in your Device Manager to see what driver is loaded. Update as neccessary.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 10-04-2005, 09:35 PM
Saintly's Avatar
Don't rely on windows update to get a video driver update.
look at the make and type of card that you have (eg ATI Radeon) and then go to the makers site to get the driver (catalyst 5.9 for the ATI card)
Saintly
'97 318Ti Sport, DASC, H&R coil overs (sold)
'07 F800ST
'10 Forester X Special Edition
Old 10-04-2005, 09:53 PM
Slackerous Maximus
HardDrive's Avatar
Yes.
The behavior described sure sounds like a faulty driver.
Do the system logs have an entry as to the cause of the reboot?
2014 Cayman S, PDK
Old 10-04-2005, 10:37 PM
911S Targa's Avatar
I've heard you have problems when you download the service pack 2 for what ever reason. Maybe others can chime in. Maybe SP 2 isnt a problem anymore.
Bill
MID9 #4
if i cant play with it ,,i dont want to own it
Old 10-05-2005, 09:04 AM
Certified Pre-Owned
SP2 came with my OS disc, I shall try and update the driver. The AntiVirus has nothing to do with the problem (its been tried).
Thanks for the help guys~!
'84 Carrera Coupe
Old 10-05-2005, 09:31 AM
SP2 caused problems when I installed it on some Dell notebooks. Check with your CPU manufacturer to see if there are any updates to fix probs with SP2 install.
Randy
'87 911 Targa
'17 Macan GTS
Old 10-05-2005, 10:41 AM
Saintly's Avatar
I have installed SP2 :
with orriginal install disks
with the sp2 patch cdrom
with the download and install later
via windows update
via SUS
and via WSUS
with no problems on any of my desktops or laptops at work or at home.
a freash install with an orriginal install sp2 CD should be no problem
When you did the initial install, did the problem exist or was it only after doing all of the patches? are you doing an express update or a compleat update? if express, i would run the other just to be sure.
Saintly
'07 F800ST
Old 10-05-2005, 02:47 PM
Send a message via AIM to michaelathome Send a message via Yahoo to michaelathome
^^^ What they said, driver issue.
Michael
Old 10-05-2005, 09:11 PM
