Please enlighten me...
Ok, I built a little work 'patio' connected to my shop, and I need ideas on how to add lighting. I thought about installing a couple of 8' flourescents about 2' away from the wall; I don't want them too far away from the wall or they might get hit.
I set this area up so I'd have a semi-protected place to do messy stuff, like shooting gelcoat or sanding. I could also get a car in here if I were to move my compressor about 2' to the right.
Old 11-17-2005, 08:57 AM
drag racing the short bus
dd74's Avatar
If you're just using the work bench area - and at night - perhaps I'd install a fluorescent strip on the wall. Not pretty, but functional.
The Terror of Tiny Town
Old 11-17-2005, 09:01 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Flourescents would probably work fine, and cheap too. What about these...http://www.lowes.com/lowes/lkn?action=productDetail&productId=27277-290-HSL300
It gets cold enough up here that sometimes fourescents won't start.
Guess you don't have that problem though...
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-17-2005, 09:03 AM
TerryBPP's Avatar
If it was me, considering its outside and subject to the elements, I would just buy 2 sets for standing shop lights. I just picked up a set at Lowe for like $35. This way you can drag them in if it starts pouring.
Old 11-17-2005, 09:10 AM
Fastening a couple to the wall seems like the quickest-easiest way to go. If you get a couple of the real simple fixtures that have no reflectors on them, you could mount the horiz., then make a couple reflectors for above out of thin plywood/white paint.
If the roof there doesn't shudder in the wind, and you aren't planning on hard-wiring them, you could hang them by chain from those pipes and use an extension cord.
Old 11-17-2005, 09:11 AM
Well I would hope that even if it starts pouring, this stuff would stay dry!
I was looking to hard-wire the lights. If you look closely you can see the weatherproof electrical box to the left of the workbench. I already have the switch installed, wired up and ready to go, just need to run some conduit.
At any given time, I could be using any part of the area, not just the bench.
Old 11-17-2005, 09:16 AM
id10t's Avatar
Run some track'd spot lights along the wall where the roof connects - aim 'em where you need 'em
Old 11-17-2005, 01:05 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Why not just run a couple of outdoor floods or spotlights?
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 11-17-2005, 01:35 PM
Seldom Seen Member
Burnin' oil's Avatar
I'd use candles or something
Why do things that happen to white trash always happen to me?
Got nachos?
Old 11-17-2005, 05:21 PM
I'm doing fiberglass layup, not trying to get laid.
Old 11-18-2005, 07:31 AM
Paper Member
Yes, but don't rule out the possibility..........
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 11-18-2005, 08:24 AM
