TerryBPP's Avatar
Project Evil E30: Houston, we have a problem
So I am spewing oil ot of the turbo exhaust side and cant figure out why. I thought it was the valve cover vent still being hooked up to the throttle body but that wasnt it. I'm guessing its the turbo seals. Any of you turbo gurus have any sugestions before I throw this turbo in the garbage and buy a new one?
Old 11-21-2005, 04:39 AM
beepbeep's Avatar
Before you change turbo, check if oil drain hose going from turbo is big enough.
If your pistons have lot's of blow-by, they will pressurize the crankcase and blow the oil trough turbo seals.
Also, if turbo is too low oil won't flow trough scavenge hose but will pool in it. It will result in blue smoke too.
Thank you for your time,
Old 11-21-2005, 07:30 AM
TerryBPP's Avatar
I'm using a 10AN oil drain line to the oil pan. Only thing I can think of is that the fitting I used to convert the outlet size to the 10 AN might be too restrictive. I'll play with it tonight and see what happens.
No blow by on the pistons.
The turbo touches the hood so I doubt that its too low, lol.
Old 11-21-2005, 07:54 AM
Is the drain from the turbo pointing straight down?
Matt B
'73 911E
Old 11-21-2005, 12:52 PM
TerryBPP's Avatar
No, it comes off at a 90 deg angle. I have seen setup like this. Wonder if straight down would help.
Old 11-21-2005, 01:22 PM
I don't know the exact specifics but some types of seals are more accepting of this. However in most cases they want the discharge to be +/- 15 degrees from the straight down position. Chances are your dynamic seal is being overwhelmed by oil and is dumping it into the exhaust turbine.
Hopefully it's not that hard to change the routing on your project!
Matt B
'73 911E
Old 11-21-2005, 02:04 PM
TerryBPP's Avatar
I'm going to change it around tonight and see what happens. Thanks for the help. I report back tomorrow.
Old 11-21-2005, 02:15 PM
beepbeep's Avatar
There you have it. It shouldn't differ more than 15 degrees from vertical line.
Oil draing going from the side will certainly result in smoke, even on a brand new turbo. There are no OEM turbochargers installed in this way. What you saw was probably coolant pipes, they are often mounted from sides.
Old 11-23-2005, 01:20 PM
