Plastic Radiator?
My Nissan has a hairline crack in the top of its radiator. The radiator is plastic (that's a new one on me), so I bought a new one, but I need to limp along on this one until the weekend when I can do the install. It's leaking a little, and I was wondering if some crazy glue will get me to the weekend?
Any ideas? Thanks. (Damned water-cooled cars) |
I don't know if I would trust super glue. Every time I have tried to "make it to the weekend" with a leaking radiator, it has come back to haunt me.
BTW, lots of plastic radiators these days... Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Could you use a soldering iron to "weld" the crack up? I've done this with plastic bumpers before
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Targa, Panamera Turbo
Chances are, the plastic is a thermo-set material which means once it has been processed and cured you can't melt it back. Plastics are catogorized into two families - Thermoplastics (which can be remelted and molded) and Thermosets (which can not be re-processed or remelted without draqstically changing the physical properties).
For high temp, automotive applications, thermosets are typically used. Not sure you will want to try a repair job to get you through.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
You are replacing it anyway, why not try the raw egg sealer method for the weekend?
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Senior Member
Duct tape? A bottle of Radiator Stop Leak? Bars Leak?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
D idn't E arn I t
JB Weld the crack.
AOC/Hogg 2028 |
Information Junky
I've done this (weld) to plastic radiators w/ good results. Tho' admittedly, I may have snuck-in some carbon fiber to add some strength to the area. oh, try not to breath the fumes.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
every time I have used stop leak...........water pump bearing fails after that.............
Thread Tools | |
Rate This Thread | |
