New kid in town
Rolex question.
Does the second hand go tick-tick-tick or is it just a smooth sweep? I’ve heard that is one way to tell real from fake, but I can’t remember what way is real.
I wish I still had 9111113443... |
smooth sweep....if you really stare at it and see the individual ticks, but there are probably 5 or so per second so from a few inches away it appears as a smooth sweep. If it's tick - pause - tick - pause, it's a quartz.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
New kid in town
OK, thanks. So it is a bit of both. The one I was looking at ticked, but like you said, it was 3-5 per second. Probably the real deal then...
I believe the current Rolex mechanical movements beat 28,800 per hour. So its 8 ticks per second will look more like a smooth sweep than will a quartz movement that ticks once per second.
That said, I suspect there are plenty of fake Rolexes out there with mechanical movements too so don't rely on this indicator alone to determine authenticity. Have an expert check it out to be sure. Regards, Markus |
The Cuddly One
Some of the latest clones are so good that they have to be verified by Rolex themselves.
-Isa 911E 3.0 (Tristezza, the Rattus Maximus) and Jimmy the Mini lll Dum vivimus, vivamus! Man braucht nicht reparieren was funktioniert! |
If the clone is that good...why buy a Rolex??
Rick 1984 911 coupe |
five mini ticks per sweep. i think. it should look smooth. and the salesman cannot be of any asian persuasion working out of a booth.
poof! gone |
Senior Member
One thing to remember is that not all of the Rolex watches use a Rolex movement. Both my Daytona's have an ETA movement right out of the factory.
The newer version of the copies are very close. Was in Hong Kong recently and had my steel Daytona on and compared it with a copy there, and we could not tell the difference for a long time. Kept mine on my arm until I figured out one small difference between the two. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The previous generation daytonas used a modified Zenith movement, the current ones are in house.
If it ticks once per second it is a Quartz movement. Mechanical movements all sweep, some smoother than others but none i know goes one tick per sec. alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
One thing to check, When you pull out the set knob to adjust the time, The second hand should STOP until you close the knob back down. I have never seen a fake that would do it and there are some nice mechanical fakes.. One final thing is the watch serial number will be stamped into the case inside the mounting lug where the band attaches. It will be on one end of the watch. I have not seen it on both ends.
The top-line Rolex replicas are VERY good, right down to serial numbers. The one model they continue to struggle with is the Daytona. The fake movements space the sub-dials out away from each other too far.
http://www.replicacenter.com/replica_frame.htm |
Any tips on how to spot a Timex clone?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
real rolex do not give accurate time
least common denominator
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
