vash's Avatar
you guys read about this freak airplane death?
great, my hometown! my brother called, i will see if he has any photos. (he is a cop)
A MAN GOT CHIPPED UP BY A JET MOTOR!
http://www.elpasotimes.com/apps/pbcs.dll/article?AID=/20060119/NEWS/601190325/1001
poof! gone
Old 01-19-2006, 02:46 PM
vash's Avatar
he said the blood blast was three jet lengths. nasty.
poof! gone
Old 01-19-2006, 02:47 PM
vott does ziss do?
ronin's Avatar
actually heard about that one on the news up here. totally horrific to say the least
Old 01-19-2006, 02:57 PM
B58/732
BlueSkyJaunte's Avatar
Pass the ol' El Paso....
ΜΟΛΩΝ ΛΑΒΕ
Got a few questions:
Why is the engine spooled up to the level to suck a person into it when passengers are boarding?
What is there left to have a funeral service for?
gary
Old 01-19-2006, 03:08 PM
Wow, that sucks!
Senior Member
Happens fairly often on aircraft carriers, or did a few years ago.
Airlines have things like this happen often, but usually not with people.
JoeA
Old 01-19-2006, 03:18 PM
B58/732
Originally posted by widebody911
Wow, that sucks!
No, it blows.....chunks.
ΜΟΛΩΝ ΛΑΒΕ
Old 01-19-2006, 03:22 PM
Semper drive!
rcecale's Avatar
A-7s and F-8s were notorious for eating people alive...care to take a guess as to why?
A-7
F-8
While I was on the Nimitz, they showed us an old film of flight ops where a member of the ground crew was ingested into the intake of an F-14 that was taxiing to park after returning from a sortee..and nobody noticed!
A few minutes after they shut down the engines and walked away from the jet, the guy worked his way back out of the intake. It seemed that his float coat (inflatable life preserver) caught on a pitot tube in the intake and prevented him from being run through the "meat grinder".
Quite a video!!!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 01-19-2006, 08:28 PM
Non Compos Mentis
Now that's a story the grandkids will never believe!
Old 01-19-2006, 08:49 PM
Semper drive!
rcecale's Avatar
He's got it on film!
Randy
One Marine's View
Old 01-19-2006, 08:55 PM
Semper drive!
rcecale's Avatar
Here's a clip of a maintainer getting sucked into the intake of a turning A-6. Believe it or not, he lived to tell the story too!
Randy
One Marine's View
Old 01-19-2006, 09:00 PM
Semper drive!
rcecale's Avatar
And here is why you need to have a "swivel-head" whenever you're on the flightdeck. Never stare in on direction for more than a second or two....
Randy
One Marine's View
Old 01-19-2006, 09:05 PM
Senior Member
Leland Pate's Avatar
That guys flashlight just happened to go in moments before his head. ?The flashlight FOD'ed out the motor and saved his life.
Chief Architect and Mastermind,
SCWDP
Old 01-19-2006, 09:21 PM
Slackerous Maximus
HardDrive's Avatar
This all sounds pretty dicey....
2014 Cayman S, PDK
Old 01-19-2006, 10:14 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
How deep is the intake on an A-6? Seems like you'd have half a chance with something like that..
Old 01-19-2006, 10:16 PM
Semper drive!
rcecale's Avatar
Jared,
I'm not sure I understand your question correctly. The intakes on an A-6 are just like any other intake....they reach all the way back to the engine.
If you were thinking that maybe the guy could have grabbed ahold of something to prevent being completely sucked in, it wouldn't work.
In this film, figure the guy weighed close to 200 lbs, 150 at least. Look how quickly he was snatched up off his feet. Even if he were some kind of bodybuilder, with muscles of steel, his reactions would have to be so quick, not to mention the amount of strength it would require to stop his body from suddenly moving so fast.
I practically lived on the flight deck while I was on the Nimitz. The experience is quite exhillerating. Especially when they have ALL the cats operating. Especially working the port side of the portside bow cat. There is a small 'safe' area that moves, depending on whether they're launching the bow or the waist cat. They actually kinda intersect, so you're constantly on the lookout. One false move and you end up worse than the guy in the second film I posted...the aircraft on the waist cat is moving at speed by the time it gets to where you are.
Randy
One Marine's View
Old 01-20-2006, 05:06 AM
Senior Member
One thing that Randy does not mention is that while these guys survived, I doubt that their "micky mouse" ears remained on their head and they were probably deaf for life after that.
The engine on most of these airplanes is between the cockpit and the tail, usually 10-15 feet aft of the nose and takes its air from the duct which runs under or beside the pilot. Its normal for a crew chief to get inside this duct and shinny down to inspect the turbine blades and check for FOD but someone is always on watch to make sure that someone does not spool the engine while someone is down in its belly.
Its a dangerous place on a carrier deck. Getting sucked in is only one of the dangers. Putting the JBD's down (jet blast deflectors) can catch someone off guard and blow them off the deck and into the water. If someone sees it happen they MIGHT be found. There was a case of a guy being blown off deck in the Indian ocean a few years back and he was picked up by a fishing boat a day or two later. Very lucky guy as most of the time they are gone forever...
JoeA
Old 01-20-2006, 05:15 AM
