D idn't E arn I t
I would assume that the issue with the rocker alignment is that there's binding - the pushrod must be hitting the inside of hte head where it passes through - in this case either - 1) a serious misalignment between the block and head missing dowl pin on block? 2) head or block have been shaved to the point where a standard pushrod is now too long for proper geometry - this would be a rare situation - but if someone shaved the head for more compression it's possible. however that's a hell of a lot of metal removal to get that kind of misalignment. Intake manifold wouldn't seal up properly anymore either unless that's been cut down to match. If you've gotten broken rocker arms, are you sure the camshaft and crank are sync'd right? If the camshaft is radical it probably pushed the valves into the piston -- and you might have coil binding up top too. Judging by the way this thing sounds this is probably not too far off. You might have to rip it apart, but fortunately, it's just gaskets and a lot of cussing. Shouldn't be more than a day and $50 or so for all the extra stuff you need.
AOC/Hogg 2028 |
Broke
Forget the messy valve adjusting. Just get an old Chiltons at the flea market and it will explain it. I'm amazed at all of the people that put the clips on a running SBC and try to adjust the valves. Oil on the headers is my favorite breath of fresh air.
My book is at home so I can't quote it, but you bring the motor to TDC (compression) and adjust a couple of valves to where the lifter is tuff to turn, then go 1/4 to 1/2 turn on the nut. Rotate the motor, do a couple of more. Repeat until done. I just can't tell you the order of adjustment without my book. I've done this a dozen times and only once had to readjust one lifter. And that was because I lost track of where I was. I think it was the beer. Good luck.
Beer is proof that God loves us and wants us to be happy. B. Franklin 93 968 Cab 81 SC Targa (Princess) Now Residing in Denmark 1973 RS Z28 Vash will never own it! |
