Perplexing paint mixing problems - need help from math guys!
It's actually for an epoxy primer.
1 quart primer taxes 1/2 ounce of hardener.
But I only need to mix 8 ounces of primer.
So how much hardener?
I figured .75 teaspoons (3/4 of a teaspoon).
But it doesn't seem to come out right.
Here's my math:
1 qt = 32 oz.
1/2 oz = 3 tsp.
I want 8 oz, so that's 1/4 of a quart.
So I need to use 1/4 of the hardener, which would be .75 tsp. (1/4th of 3 tsp = .75).
Where am I going wrong, math dudes!
Old 02-20-2006, 01:00 PM
Certified Pre-Owned
BGCarrera32's Avatar
Set up a ratio (assuming your conversions are correct-I didn't check)
32 oz over .5 oz = 8 oz over X
8*.5= 4
4/32= .125 oz hardener
If 1/2 oz = 3 tsp like you say (I didn't check)
.125 oz would be .75 tsp
But then again I stink at math, so wait for another opinion.
'84 Carrera Coupe
Old 02-20-2006, 01:40 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
I got .125 oz also.
How many cc is that?
You know, for using a syringe...
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 02-20-2006, 01:56 PM
Send a message via AIM to wludavid
0.125 US fluid ounces = 3.69669121 cc
approximately.
1987 325 eta
Old 02-20-2006, 02:48 PM
Detached Member
Hugh R's Avatar
1 Qt. = 32 oz
You want 8 oz which is 25% of a quart
0.5 oz of hardener x 0.25 =0.125 oz. or 1/8 of an ounce.
Hugh
Old 02-20-2006, 04:54 PM
I'm curious as to what kind of epoxy primer you are using. The epoxies I've used are 4:1 or 2:1 ratio for primer to activator.
Old 02-20-2006, 05:10 PM
Ok, never used that brand. I see that their epoxy mix ratio is 2:1 which is similar to other brands.
Old 02-20-2006, 05:43 PM
