WI FI question
What determines when your wireless laptop will not automatically assign an ip address from a router, even though the "obtain ip automatically" default is chosen both on the router setting and the laptop itself. I've fixed it by assigning it manually but it is a pain when it gets knocked off. I'd like not to have to toggle between the two and always have it automaticaly detect wireless signals. Anything else I might be missing? Thanks.
Old 02-26-2006, 04:35 PM
Slackerous Maximus
HardDrive's Avatar
I'm not sure I am following you here.
a) Sometimes you cannot get an address from you router, so you setup a fixed address?
OR
b) You want to wander from network to network, but some of the them require a fixed address, while others give you one automatically?
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 02-26-2006, 06:08 PM
It seemed my wireless devices have changed their setting with nothing done on my part. Were once they would connect automatically, I now have to manually enter all the ip data and make the connection. I'm just not sure what changed? And, yes I don't confess to be a compete networking wizard. Thanks. Also in area's that I would grab an unsecure network before, now will grab the signal but just won't assign an ip address.
Old 02-26-2006, 07:14 PM
Banned
maybe you have more than 1 DHCP server running?
Old 02-26-2006, 08:24 PM
Senior Member
Are you sure that someone else has not been playing with your system? Normally things like this do not change themselves.
Old 02-27-2006, 06:39 AM
Can you still access the router? Have you gotten into the router and verified the configuration?
The only other thing that I can think of that may cause this behavior is that if a feature was turned on that allowed only certain MAC addresses to receive IP addresses.
Old 02-27-2006, 07:51 AM
