Banned
Any Cisco frame-relay gurus in here?
These puppys will not talk.
Why is the line protocol up, but they won't transfer traffic? Does it matter that the DLCI is the same? R1 Serial1 is up, line protocol is up Hardware is HD64570 Internet address is 192.168.100.129/26 MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 69, LMI stat recvd 0, LMI upd recvd 0 LMI enq recvd 1132, LMI stat sent 1071, LMI upd sent 0, DCE LMI up LMI DLCI 1023 LMI type is CISCO frame relay DCE FR SVC disabled, LAPF state down Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0 Last input 00:00:09, output 00:00:09, output hang never Last clearing of "show interface" counters 03:10:23 Input queue: 0/75/13/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1307 packets input, 20325 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles R2 Serial0 is up, line protocol is up Hardware is HD64570 Internet address is 192.168.100.130/26 MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 1140, LMI stat recvd 1083, LMI upd recvd 0, DTE LMI up LMI enq recvd 57, LMI stat sent 0, LMI upd sent 0 LMI DLCI 1023 LMI type is CISCO frame relay DTE FR SVC disabled, LAPF state down Broadcast queue 0/64, broadcasts sent/dropped 155/0, interface broadcasts 0 Last input 00:00:02, output 00:00:02, output hang never Last clearing of "show interface" counters 03:10:14 Input queue: 0/75/5/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1300 packets input, 21850 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles Last edited by HardDrive; 05-03-2006 at 10:07 PM.. |
It's been awhile since I've done a config like that, but I'll give it a shot.
The DLCI 1023 is only for exchanging LMI status enquiries and responses, same as DLCI 0 if you used the Ansi-AnnexD LMI flavor. You need to build the sub-interface, assing a DLCI to the sub-interface, use DLCI 100 for example and map the IP address. Hope that helps, it's been a long time since I've configured something similar. Good luck.
Ken '92 964 C2 |
I'm a Cisco dude, can you send the int configs?
Cisco dude, was a friend of mine...." I'm sorry, but I've got WAR on my mind this morning.... ps: The band, not the fiasco
You need to send the interface configs, the output of "sho int" doesn't give us enough info.
Banned
Thanks guys. I'm off on another disaster, but I will see if I can post configs later.
