In the shop at Pelican
Jared at Pelican Parts's Avatar
sounds like a wax ring to me. Very easy fix.
Old 06-18-2006, 04:35 PM
R Wilco,
Thought the same thing when I first read about his problem, then I reread it. His leaking is in the bowl, not the tank.
Dennis
Old 06-18-2006, 04:38 PM
Phoenix has had some strong winds lately, so I bet it's just air pressure changes like what dhoward pointed out. Or a cactus wren built a nest in your roof vent pipe. Go up there and check it out. I had one get stuck in my clothes dryer vent one time. If this has been going since you moved in, may be due to poor plumbing or no vent pipe.
Old 06-18-2006, 04:41 PM
Student of the obvious
LeeH's Avatar
It's a fairly new problem. I popped it off and hauled it into the back yard. Interior looked fine as far as I can see. Wax ring looked fine - no signs of a leak. I put a piece of plastic wrap over the hole. It's moving a little, but there doesn't seem to be enough suction to pull the water level down as far as it's been going. The only conclusion I could come to was a crack up inside.
We just got back from Lowes with the new unit. Hopefully this wasn't $188 waste of money. Either way my wife is happy as the tank lid got cracked a few years ago when a decorative tile fell off the wall. Time for the install.
Lee
Old 06-18-2006, 06:42 PM
19 years and 17k posts...
azasadny's Avatar
Lee,
Remember that when you caulk around the bottom of the toilet that you don't want to caulk behind the toilet. That ways, if there's a leak, the water will come out and you'll see it. If you caulk it all up, water can sit on the wood subfloor and rot it out without you even noticing. Good luck!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-18-2006, 08:00 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Wax ring isn't it. That only seals the union between the fixture and the flange. You could put a toilet in your back yard, fill it with water, and the level would stabilize at the point where the trap is full. Crack, partial clog (siphoning), or vent pressure.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 06-18-2006, 08:53 PM
LeeH's Avatar
New unit is in. I checked all the roof vents and they are clear. We'll see how it goes. Thanks for all the advice!
Lee
Old 06-18-2006, 09:31 PM
There was an episode of Ask This Old House that had this problem last year. It was a clogged vent pipe. When water was added to any drain that shared this vent it would create a suction and drain the traps.
Of course they had a video camera they lowered down the vent to find and show the dead bird or something.
Old 06-18-2006, 10:02 PM
