Rodeo's Avatar
Plumbers?? How to drain hot water heating system?
Any help would be appreciated. I'm gutting a small house with baseboard heating on two floors, appx 1200 sq feet of floor space total. I'm going to take out all the baseboard pipes, so I need to drain the heating system first.
I found the drain valve at the very bottom of the oil-fired furnace, which is in the basement. There's pressure behind it, if I open the valve the water comes out pretty good. So I put the hose on it.
I need to take the hose up out of the basement because there is nothing to drain to in the basement. The water does not flow when the hose is above grade, I guess there is not enought presure.
Is there some kind of siphon device that plumbers use?
Also, I assume I need to introduce some air into the system to avoid a vaccum, how would I do that? My idea was an ax to one of the pipes on the second floor, but there's probably a more technical method
We will stay the course. [8/30/06]
We will stay the course, we will complete the job in Iraq. [8/4/05]
We will stay the course *** We’re just going to stay the course. [12/15/03]
And my message today to those in Iraq is: We’ll stay the course. [4/13/04]
And that’s why we’re going to stay the course in Iraq. [4/16/04]
And so we’ve got tough action in Iraq. But we will stay the course. [4/5/04]
Well, hey, listen, we’ve never been “stay the course” [10/21/06]
--- George W. Bush, President of the United States of America
Old 07-02-2006, 07:01 PM
Rodeo's Avatar
I see you're from the south
Oil-fired furnace heats the water. Water heats the house.
Old 07-02-2006, 07:11 PM
Rodeo's Avatar
Did I just step on a joke?
Old 07-02-2006, 07:13 PM
Rodeo's Avatar
They'll tell me why hot water needs to be heated?
Old 07-02-2006, 07:18 PM
Senior Member
Is there any place in the area that is below the level of the furnace in the basement? Front or back of the house by the drive lower? If so then you can put a long hose on it, then siphon the water out by creating a suction on it.
We did this overseas with the same style heating systems in Germany. Sometimes took a real long hose but worked.
Rodeo's Avatar
Joe! thanks for the suggestion, unfortunately no lower ground within a reasonable distance.
Old 07-02-2006, 07:23 PM
Rodeo's Avatar
That's an idea! I could probably even get away with a smaller 10 gallon bucket, just adjust the flow so it doesn't overwhelm the pump.
Now if I can find that old sump pump I haven't seen in a long, long time ....
Old 07-02-2006, 07:37 PM
Senior Member
Pump it into several 5 gallon gas cans, then carry it upstairs and dump it. Then open the cans up and let them air out before using again.
Old 07-02-2006, 07:45 PM
Senior Member
Procon,
Thats way overkill. I drained my 15,000 gallon pool with one of those a month ago. Took 3 hours so its pumping a lot of water.
If its anything like we had in Europe, the system Rodeo has does not hold that awful much water I believe.
Old 07-02-2006, 07:49 PM
Rodeo's Avatar
Found it! Thanks Procon and Joe, I'm going to get the biggest bucket I have and stick the sump pump in it. I'll just cut one of the lines on the second floor after it drains a bit to avoid a vacuum.
Here's the reason for the gut, btw. Thought I'd get some exercise, get away from my desk, and save some $$ by doing the demo myself.
I've practically filled the THIRD 30 yard dumpster, and I'll need a fourth to finish. Who knew? But the place will be like new construction for the plumber, electrician and carpenters.
Old 07-02-2006, 08:08 PM
Banned
fastpat's Avatar
That's one of the most efficient heating systems there is, the only way to improve it is to upgrade the burner, and switch to gas at the same time. You can't find a better system, and it's almost dust free, no filters to change, and on and on. I installed one in a house I owned, vintage 1917, worked great and almost totally silent.
Old 07-02-2006, 08:30 PM
Rodeo's Avatar
Pat, I agree, forced hot water is a great heating system. We have it in our house too, used to be fired by this massive asbestos-covered thing in the basement that looked like it belonged in an old ocean liner. Upgraded to one of these babies a few years ago.
I'll keep the hot water system in the carriage house, but I really dislike the baseboard radiators. Going to try to find some cool old cast iron radiators instead.
Old 07-02-2006, 08:58 PM
If you haven't figured out the venting yet, open a faucet.
Sherwood
Old 07-02-2006, 10:35 PM
Senior Member
What's nice is to lay piping inside the floor (usually concrete) and run the hot water there. Not sure how you would do it on a multi-story house.
When you wake up and put your feet on the floor, its is nice and toasty and stays that way all day long during winter.
Old 07-03-2006, 05:17 AM
Rodeo's Avatar
Sherwood, the heating is a closed system. I don't think opening a faucet would let air into the heating pipes.
Joe, my brother has radiant heat. It's freaking great! You do it on a multi-level by opening up the ceilings and running the flexible water pipes along the floor joists of the room above. Too expensive for this project though.
Radiant is actually the most efficient, and you can run the heat lower because when your feet are warm, it "tricks" your body into thinking its warmer than it actually is.
Old 07-03-2006, 05:32 AM
Senior Member
The other reason why its so effecient is that heat raises, so putting the heating elements on the bottom is best, while the cooling vents for A/C in the "ideal" house should be coming somewhere out of the top of the room, and letting the air descent and cool as it does.
Someday when I build my "last" house will make it this way.
Old 07-03-2006, 05:46 AM
"I don't think opening a faucet would let air into the heating pipes."
Errr. Excuse me for not paying attention. Doesn't a closed heating system still have a connection at the radiation source (if exposed) or are they all soldered?
If you plan on removing the baseboard elements anyway, wouldn't a well-placed slice through the highest-elevated baseboard heater pipe accomplish the desired venting?
Sherwood
Old 07-03-2006, 10:00 AM
