-   -   Wireless home internet - how to make it so neighbors don't use it? (http://forums.pelicanparts.com/off-topic-discussions/299870-wireless-home-internet-how-make-so-neighbors-dont-use.html)
Craig 930 RS 08-21-2006 10:05 AM
I have a Linksys 2.4 GHZ wireless access point router - no home network, just installed a few yrs. back so I could use the laptop anywhere in the house.
Where on the ol' computer do I configure this so neighbors will stop piggybacking and using my Internet Provider to access their stuff?
Gotta be simple, but heck if I know how......
id10t 08-21-2006 10:10 AM
Depends on your router, and how many wireless devices you want to use. If it is just the one laptop, I'd use MAC address blocking and only allow the laptop. The MAC address is a hard-coded hardware address for your network card, and many access points can deny *all* wireless traffic except for that specific address.
Of course, you could have lots of fun with whoever is leeching off your connection - replacing images, redirecting all traffic, etc.
Edit - using a WEP key can keep many people out, but it is crackable with not a lot of effort. WPA may be better, but I think there are tools out to defeat that as well.
widebody911 08-21-2006 10:13 AM
Mac address blocking and 128-bit WEP will solve 99.95% of the problem. A motivated neighbor could still slurp 30 minutes of traffic and break your WEP.
Here's what you do: buy a 2nd router off of ebay, spoof your neighbors IP's and stuff the pipe full of kiddie porn.
450knotOffice 08-21-2006 10:17 AM
Do you still have the old installation disk? If so, reinstall the software. Basically start all over again but this time when it asks you which level of security you want, go to the maximum offered.
That's the only way to do it that I know of.
slodave 08-21-2006 10:19 AM
You can also hide the SSID. While it does not give you encryption, it does make it harder for your neighbor to find your AP.
Dave
Craig 930 RS 08-21-2006 10:20 AM
I'm too tech stupid with this kind of stuff.
Guide me a bit more? ie 'Start, Programs,' etc
450knotOffice 08-21-2006 10:22 AM
Craig, do you have the disk?
legion 08-21-2006 10:22 AM
What's been said above.
Do you know how to log onto your router?
Mine I just punch the router's IP address into my web browser, and it comes up with a web page that allows you to configure all the settings.
I have all MAC addresses but my home and work laptops blocked, but no other security.
If you want to have some fun, you should also be able to look up a log of what IP addresses have been accessed through your router. Figure out which are your neighbor's and block them.
fastpat 08-21-2006 10:28 AM
If your home is more than 150-200 feet from your nearest neignbor, that should be sufficient. In CA, when my neighbor was about 30 feet away, I used encryption and MAC id selection which worked.
Craig 930 RS 08-21-2006 10:30 AM
Scott - I don't.
Start here?
My Network Places
Local Network
Linksys BEFW11S4 V.2
Asks for use name and password.
I don't recall ever giving it one....
This has gotta be my IP addy: http://xxx.xxx.x.x.xxx/
If this is the correct path, how to access this?
nostatic 08-21-2006 10:32 AM
hate to tell you, but this change is dead simple on a Mac ;)
I leave my wireless network open though. When I moved in I had to wait a week for my DSL to be installed. I used my neighbor's network during that period. When I got mine up and running I left it open. I'm not running any servers on my wireless network and Macs are pretty secure. I think of it as a public service. I don't get charged by the bit, so what's the harm? If someone does something untoward, safe harbor should cover me.
Craig 930 RS 08-21-2006 10:32 AM
Whereupon I get this:
401 Authorization Required
This server could not verify that you are authorized to access. Either you supplied the wrong credentials(e.g., bad password), or your browser doesn't understand how to supply the credentials required.
widebody911 08-21-2006 10:35 AM
For your linksys, the URL for the admin i/f should be http://192.168.1.1/
IIRC, the user name is blank and the password is 'admin'
Craig 930 RS 08-21-2006 10:38 AM
Damn. You guys are gooooood. Got this - next?
Wireless: (MAC Address: 00-90-4B-E0-99-D2)
EnableDisable
SSID:
Allow "Broadcast" SSID to associate? YesNo
Channel: 1234567891011 (Domain: USA)
WEP: MandatoryDisable
WAN Connection Type:
(MAC Address: 00-06-25-9A-93-2B)
Obtain an IP automaticallyStatic IPPPPoERAS (for SingTel users)PPTP Select the Internet connection type you wish to use
ruf-porsche 08-21-2006 10:40 AM
Just dump the wireless or turn it off when you are not around
widebody911 08-21-2006 10:44 AM
Next you need to get the MAC's of the devices that will be allowed onto your network:
WINDOWS NT / 2000 PROFESSIONAL or XP:
* Using your mouse, click on the Start Button.
* Click on Programs.
* Next, click on Accessories, and then Command Prompt.
* Once a small black window appears, type in ipconfig /all (with a space between the g and the /).
* Locate the number to the right of Physical Address. This is your MAC address.
or
* After clicking on the Start Button, click on Run.
* Type in the word command
* Click on OK.
* Once a small black window appears, type in winipcfg.
WINDOWS 95/98/ME:
* In the white space of the window, type in the word winipcfg
* Click on "OK".
* Look under the info for the Ethernet adapter. (Your system may also have a modem.)
* The number next to "Adapter Address" is your MAC address.
930addict 08-21-2006 10:52 AM
Here are three things you should do to give yourself max protection possible.
1. Change your SSID and turn off SSID broadcasting from your router.
2. Lock down your MAC address.
3. Use WPA instead of WEP as WPA dynamically changes keys which prevents key recovery attacks that WEP lends itself to.
The SSID and MAC address configurations will be performed on your router. So you will need to log into your router. If you go to command prompt and type ipconfig /all you should see an IP address for your default gateway, which is your router. If you haven't changed the default settings the IP ddress will look something like 192.168.1.x. Open up a web browser and type httP://ipaddress and hit enter. You should see the login screen for your router. You need to login to the router. Leave the user name blank and enter admin in the password field and press enter. You will then be taken to the router confiuration screen where you can configure security options.
edit: oops widebody got here first. SmileWavy
lendaddy 08-21-2006 11:03 AM
Is there a way to find out if they are/or have been using your signal?
930addict 08-21-2006 11:04 AM
Oh and I just read that this particular router (even with the latest firmware) doesn't support WPA so WEP would be the next best thing.
930addict 08-21-2006 11:09 AM
Yes. Routers log the IP and MAC address of the system that tried to log into it as well as systems that are currently logged into it.
