Virginia Rocks!
VaSteve's Avatar
Help! Broke Windows.
I did something to the taskbar at the bottom of my screen. Now I can't see the programs that are running. The only way to figure it out is to Alt-Tab between programs. What did I do, how do I fix it?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 08-29-2006, 08:12 PM
slodave's Avatar
Try putting the mouse near the bottom of the screen where the bar was. Does the pointer turn into an up/down pointer. If so, click and drag the mouse up. It should enlarge the bar.
Dave
Old 08-29-2006, 08:27 PM
Virginia Rocks!
VaSteve's Avatar
Yeah, I can do that, but it's still blank wven if I drag the bar halfway up the screen. It has something to do with the dotted line next to the start button I think. I had two dotted lines earlier (do to some goof up) and got rid of one - and my tasks!!
Old 08-29-2006, 08:31 PM
slodave's Avatar
Right-click on the bar and check to see if "Lock the Taskbar" is check. If so, uncheck it and see if you can drag the "dotted line" left or right. If it is already unchecked, leave it that way and try to drag left and right. You can also right click on the bar and see what toolbars are being shown. Gotta run, hope this helps.
Dave
Old 08-29-2006, 08:39 PM
Virginia Rocks!
VaSteve's Avatar
I have right clicked and mesed with every setting in that menu. No luck.
Old 08-30-2006, 04:58 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
whoops answer to the wrong problem. What version of windows are you running and can you see the icons on your desktop?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 08-30-2006, 05:57 AM
id10t's Avatar
Grab the little dotted line with your mouse and slide it over to the right...
Old 08-30-2006, 06:02 AM
Virginia Rocks!
VaSteve's Avatar
Idiot, it won't slide.
Tim, it's home XP. I can see the general icons "IE", etc. But if I have 4 IE windows open, I couldn't look at my desktop and see them..
Old 08-30-2006, 06:18 AM
Tim Walsh's Avatar
k, it sounds like you can see the task bar/start button but running application area is completely empty or does it have a few icons next to the start button and/or a few next to the clock, if so which side has them?
Tim
1973 911T
2005 VW GTI
Old 08-30-2006, 06:49 AM
Virginia Rocks!
VaSteve's Avatar
No icons next to start (never were though, I don't use it that way), a few next to the clock.
There is some website with a bunch of VBS scripts to fix stuff like this. I think I hosed up the registry somehow. I can't run it till I get home, but that must be the cause. Or, I have heard a worm can cause this.
Old 08-30-2006, 07:52 AM
slodave's Avatar
Anyway to send a screen shot later?
Old 08-30-2006, 09:45 AM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Right click at the bottom / Properties / check Always on Top
From there change all the things you may need ...
If not just reinstall Windows!!
Jordi Riera
'84 930 (modified)
Old 08-30-2006, 09:51 AM
Virginia Rocks!
VaSteve's Avatar
i forgot all about the issue, fired up the PC and it's fine now. WTF?
Old 08-30-2006, 05:56 PM
