Slackerous Maximus
Mac question...removable drive
I put together a external drive enclosure using a 2.5 drive for my wifes Mac. She saw mine and had to have one.
How do I get into the disk managment utilities to create a partition on the drive? Should the OS automatically pop up with a 'new mass storage device found' message of some type?
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
When I installed my new SATA drives OS X recognized them and popped up the disk utility to partition. If it's not being recognized try going to Applications-> utilities->Disk Utilities. If it's not there then oyu may have a problem with the drive or enclosure. I assume you are connecting via on board firewire or USB?
The Unsettler
Problem with Macs which is actually a beni is they read and write just about any format, DOS, Fat32, Unix etc... so it may not always pop as unitialized.
Use Disc Utitlites. May also be a jumper issue. All of my removable 2.5's use no jumpers at all. DId you get a USB enclosure or Firewire. I have both and the Firewire is so much better then the USB versions. I find the USB cases need 2 usb ports to supply enough power and then sometimes it's a pain to get the disc to mount. Get one of these cases, http://macally.com/spec/firewire/storage/25enclosure.html Scott
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Slackerous Maximus
I formated the drive with an extended partition with journaling enabled. I have not clue what journaling means in Mac land. Is this some sort of indexing service that maintains a directory of everything thats on the drive? Thanks guys
The Unsettler
Mac OS X 10.3 and 10.4 incorporates a journaled file system, which will automatically log any file modifications. If your computer crashes badly enough to require a restart (or a restart from a power failure), the OS will then use the journal to aid in fixing any disk problems caused by the crash. Scott
