Digital Camera Help
All of a sudden, Windows XP doesn't recognize my Olympus IR 300 camera. Always did before, and auto ran camera and scanner wizard.
Still sees it, but only as a removeable storage device. WTF did I do now?
Howard
73 914 2.0 'Suzi'
73 914 5.0 'Moby'
99 996 Tip Cpe 'Dietrich'
www.thehowardagency.com
http://www.youtube.com/watch?v=bOY2x-Uh6cU
Old 09-10-2006, 07:32 AM
Maybe not as simple as this, but mine does the same thing..unless I make sure I turn the camera on after hooking it up. If I turn it on before hooking it up, it won't recognize it. Hope this helps.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 09-10-2006, 08:07 AM
charleskieffner's Avatar
howard clear your screen so only icons appear. plug camera in. turn camera on. puter should start making noise(scary) and wa-la screen should pop up showing pics being downloaded. make sure camera batteries are new or charged fully. hope that helps.
Old 09-10-2006, 08:11 AM
Interesting. Two choices on the camera screen when attached to USB, 'PC' or 'Print'. Select PC=Storage device, select 'Print' and wizard starts. When using print, I can't delete pix from camera (with windows).
Plug and Pray. Thanks guys.
Howard
73 914 2.0 'Suzi'
73 914 5.0 'Moby'
Old 09-10-2006, 09:12 AM
You do not have permissi
john70t's Avatar
Double check control panel/system/device manager for the device also(?). Nothing should have changed it as default.
Old 09-10-2006, 09:15 AM
since i have a 2 story house and a pool below......................at this point, my camera and computer would be sailing over upstairs wall into the ...................ABYSS! kersplash!
has anyone been on your computer since the last time you were on? my kids USED to crash me all the time. now NOBODY screws w/my puter................nobody!
i found that going direct off of my camera vs card reader always worked. card reader was finicky. it was a 6 in 1 reader..................kersplash!
Old 09-10-2006, 09:21 AM
Detached Member
Hugh R's Avatar
No solution to why it happened, but right click on "Start" and use explore to see if you can find the external drive (E) usuallly and see if you can open your pics and copy to your hard drive.
Hugh
Old 09-10-2006, 03:42 PM
