Platinum Member
Small engines - hard starting....
Does anybody here understand small engines, especially electronic/automatic chokes? I have a go kart, bought for the kids last winter, that is nearly impossible to start.
Once it gets going, it runs great, but to start it, I usually have to take off the intake (so I can see the carb) and hold the choke open with a screw driver.... once it starts, the kids have to drive it around before it will idle. |
Unregistered
Starting fluid.
Detached Member
Those small engines eat up spark plugs.
Hugh |
You do not have permissi
The choke could probably be adjusted so it open all the way,same as the screwdriver-trick. A new/cleaned air filter will get rid of that variable. The choke should be closed when cold and fully open when warm.
The bad-running-while-cold symptoms could be a fuel filter/pump problem, or possibly another variable. Also checking the timing to the manufacturers specs won't hurt a thing. Fuel. Air. Spark(at the right time).
Meanwhile other things are still happening. |
ditto starting fluid.
big blue tricycle stare down the darkness and watch it fade |
yup again starting fluid. I have a lawnmower like that. You pull and pull and pull, no go. A few squirts of starting fluid and it runs like a champ!
-Tom '73 911T MFI - in process of being restored '73 911T MFI - bare bones '87 924S - Keep's the Porsche DNA in my system while the 911 is down. aka "Wolf boy" |
Platinum Member
Tried starting fluid today. It still takes too long to get it running right.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
huh...you did get the SF right down the carbs throat right?
Sounds like a very weak spark, the SF shouls flare right up.
Platinum Member
it does fire on the starting fluid. Can't keep it running long enough to 'warm up' I don't think the automatic choke is working correctly.
Banned
2 stroke ?
heat the spark plug with torch [out of the motor] reincert HOT that both cleans off the oil and prevents refouling or use a super hot plug to warm up and switch back to normal for running btw ONLY premix enuff oil/gas to run that day premixed fuel goes bad very fast so drain both the tank and carb |
Platinum Member
Nope, 4 stroke. Spent a few hours on google last night, it is a GY6 type engine, 150cc. I'm 90% certain the carb is screwed up.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 10-15-2006 at 07:48 AM.. |
