-   -   Oil over fill normal 4cyl engine: Problem? (http://forums.pelicanparts.com/off-topic-discussions/314370-oil-over-fill-normal-4cyl-engine-problem.html)
Hendog 11-10-2006 09:24 AM
I show about a litre (quart) oil over filled on my Mazda 2.2 l engine. What happens to the engine/oil in this case? Is it possible for the oil to surge up the dipstick tube and spill out during higher revs? I guess I should just drain the extra oil out.
Jeff Higgins 11-10-2006 10:02 AM
This will often lead to leaks at either end of the crank on the main bearing seals. On the front, it will make a mess. On the back, it could get all over the clutch, requiring a clutch replacement. It won't come up out of the dipstick tube; that would be the least of your problems if it did.
Joeaksa 11-10-2006 10:43 AM
Some engines the crank will hit the oil sitting in the bottom, causing damage at times. Best to drain or suck a bit out and get it closer to the right level. How far over the max mark is it showing now?
Hendog 11-10-2006 11:11 AM
Joe, the space between the low and high mark is approximtely the same amount by which it is over that high mark; does that make sense?
