Hendog's Avatar
Question Oil over fill normal 4cyl engine: Problem?
I show about a litre (quart) oil over filled on my Mazda 2.2 l engine. What happens to the engine/oil in this case? Is it possible for the oil to surge up the dipstick tube and spill out during higher revs? I guess I should just drain the extra oil out.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 11-10-2006, 09:24 AM
This will often lead to leaks at either end of the crank on the main bearing seals. On the front, it will make a mess. On the back, it could get all over the clutch, requiring a clutch replacement. It won't come up out of the dipstick tube; that would be the least of your problems if it did.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 11-10-2006, 10:02 AM
Senior Member
Some engines the crank will hit the oil sitting in the bottom, causing damage at times. Best to drain or suck a bit out and get it closer to the right level. How far over the max mark is it showing now?
Old 11-10-2006, 10:43 AM
Hendog's Avatar
Joe, the space between the low and high mark is approximtely the same amount by which it is over that high mark; does that make sense?
Henri
Old 11-10-2006, 11:11 AM
