Best Way to Cut 7 Inch Holes for HVAC Duct
I need to cut four 6" or 7" holes for installing round metal ductwork.
What is the best way to do this? I'll be cutting through thin fiberglass, ABS plastic and five inches of rigid foam (hovercraft). I was not sure until just now if the openings were going to be square, round or odd shaped so I picked up a 7 amp reciprocating saw from Harbor Freight ($5 off coupon plus last day of sale = $32). I'm going to make a cardboard template using drafting tools, and mark the cut holes with a magic marker. If there is a better way to cut holes, I'd like to know. Some of the working areas may be tight and I might end up on my back.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
one of gods prototypes
i would say start with a dremel or jig for the fiberglass/abs....then use a drywall saw for the foam.....a tight circle is going to tricky with a sawzal imo.
can you get a hole saw that big? if you're stuck with the sawzal then cut/grind the blade so it's thin (the back side....not the thin side), it'll make getting an accurate curve easier (thick blades don't turn tightly easily) i think that made sense
Brought to you by Carl's Jr. Last edited by bell; 11-13-2006 at 04:42 PM.. |
That's it, two of the holes can be done by hand. The other two cuts through the thick foam and ABS can be done with the sawzal. I have a carbide blade pack by "boa", the little one (thin) looks like it can do tight curves. EDIT: My Roto-Zip is still in several dozen pieces, POS.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 11-13-2006 at 04:51 PM.. |
Semper drive!
If you can get a sawzall on the area you need to cut, why not try a RotoZip instead? Much smaller piece of equipment to work with and the rotary action of the cutting bit will allow you to follow the curve of the hole much easier.
Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Semper drive!
Well, I guess you've already considered this then. ![]() Randy
Dog-faced pony soldier
Isn't that a means & methods issue?
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Platinum Member
Yep, roto-zip=POS. Mine failed twice, this time terminal. If it is flat, use a router with a circle cutting attachment. If not, sawzall, and a Dremel for cleanup.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
My buddy also had a Roto-zip, his also kept locking up on him. The bit gets locked on and will not come off. I had my parts soaking in PB Blaster for a year before they came apart, now I can't figure out how to put it back together. I guess I'm no Henry Ford, his deal was watches as a boy.
19 years and 17k posts...
I use a Porter Cable reciprocating saw with Bosch "fine material" blades to cut this sort of material. I'm getting pretty good with this saw...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Semper drive!
Interesting that you've had problems with your RotoZip. I've had mine since early 2000 and have used it quite a bit without issue.
I've cut everything from drywall and pegboard to rebar and ceramic tile, using the appropriate blades. Never an issue with this thing at all. What stage if disassembly is yours in? Post some pics and surely we can help you work out the re-assembly procedures. Randy
Semper drive!
You might also wanna try cutting the foam with an electric carving knife. The same kind you use on a Thanksgiving turkey.
![]() My wife refinished a sofa and used one of these to cut the foam for the cushions. Worked like a champ. Not sure how it will do on the ridgid foam you're talking about, but worth a try. Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum Last edited by rcecale; 11-13-2006 at 07:55 PM.. |
The sawzall is what I would use to cut the hole also. I cut holes all the time to run duct work through all sorts of places. Just be really careful were you cut any exposed holes or ones lack of skill shows big time.
Have you figured out the patterns for the holes cut on the non flat surfaces? |
Simple works too, a old picture below, hand held hole saws really work well, a classic.
I'm with Bill
I just wait until 1st thing in the morning then punch the hole out with this "tool".
Edited. -Z-man.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Bosch 1590/1591 jigsaw for the glass/abs ($149 at Lowe's); uber-accurate. Cut the foam with Sawzall or keyhole saw and dress up with 40 grit sandpaper.
I really just bought the reciprocating saw for the ABS and foam sandwich. Thanks for the input everyone.
