Senior Member
Kurt,
Simply take the plug in memory chips out and try to reboot it. If it boots fine (but slower with no RAM) then you can then put one of the old RAM chips back in.
Make sure you ground yourself before touching a memory chip.
joe
Old 12-05-2006, 07:46 AM
Friend of Warren
Originally posted by Joeaksa
Kurt,
joe
I will give that a try tonight!
Kurt V
Old 12-05-2006, 09:00 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Reseating the memory may work as well.
I would invest in a set of tiny tools to work on the laptop, remove the drive, back up critical data and troubleshoot per the maual.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-05-2006, 09:25 AM
Friend of Warren
I do have the tiny tools from working on regular PC's!
Kurt V
Old 12-05-2006, 09:30 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
So?
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 12-11-2006, 06:49 PM
Friend of Warren
Originally posted by dhoward
So?
So switching out the memory didn't work. Time to take it to someone that does repairs for a living. I will let you all know what it turns out to be!
Kurt V
Old 12-12-2006, 06:07 PM
Senior Member
So what happened to the laptop? Did the tech figure it out yet?
Old 12-18-2006, 03:36 AM
Friend of Warren
The local guy has been closed for the last few days, so no update yet!
Kurt V
Old 12-18-2006, 06:44 AM
Kurt,
If you want, bring it up. That's pretty much what I do for a living. We can throw the drive into another laptop see if we can get the data off at least.
Let me know.
Joe
Old 01-05-2007, 01:18 PM
Senior Member
Well, what's happened with it????
Old 01-06-2007, 06:35 PM
Friend of Warren
Wel it turns out that the video card is bad. And the video card is part of the motherboard. The computer guys for some reason only got about 1/3 of the data I have on the hard drive. None of the pictures.
Joe, I had no idea that you are a computer geek! Let's work out a time to get together. You can see what you can do to get the info off the hard drive and I can go over your list of things to do on the 911!
Kurt V
Old 01-07-2007, 10:20 AM
Senior Member
Kurt,
I was going to SMS in Springfield in 1973 or so and trained on an old IBM 360, one of the old tube type and punch card computers. Been playing with them ever since. I fly jets for a living but putz with anything electronic in my spare time.
Now on your laptop. You should be able to plug a monitor into the back of the laptop, push the FN and either F5 or F8 key to switch the video output to the monitor. Then you can plug a USB external drive into the laptop and transfer the files you want to save there.
Alternate option is to remove the hard drive and install it into an USB external housing. Then it will plug into a USB port on any computer where you can then copy your data anywhere.
DO NOT format the hard drive or give up on your photos! I personally would remove the HD and put it in an external USB housing. Then plug it into a desktop and try to recover the lost data. I have done it before and have been anywhere from 10% to 80% successful, so its worth a try.
Will email you my direct email address. May be coming to Springfield (Brother still lives there) in the future and its not that far from Jeff City.
Joe
Old 01-07-2007, 10:45 AM
