Craftsman impact gun problem
Last year, a friend gave me a medium duty 1/2 drive impact gun from sears as a wedding gift. I had my compressor loaned out to another friend for almost a year, so I never used the impact gun.
Last night, I was swapping on my winter tires and decided it was time to crack the box and use my "new" tool. I oiled it and ran the compressor up to 90PSI. The thing wouldn't even loosen my lugnuts. In fact, I could hold the socket and prevent it from turning, even at the highest setting. It says it's good for 350ft/lbs. I checked the manual... I had the right air pressure and the right size air hose. Is there something else that I can check? I don't have a receipt so Sears won't help me.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Hell Belcho
How big is your compressor's tank?
If it's faulty, you can always take it back for a new one
Saved by the buoyancy of citrus. |
20 gal. Not ideal, and I'm going to get an upright 60 in the spring.
Still, I should be able to power an impact gun, even if the compressor cycles like mad.
Slackerous Maximus
I don't think you need a receipt to take it back to Sears.
Call them.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
I called them and the guy was a peen about the fact that it's 1.5 yrs old and I don't have a receipt. Maybe I need to just bring it in and speak loudly.
Hell Belcho
I don't know. I used to run a 26 gal and I had trouble running an impact. I think it may also have to do with the HP of the motor as well.
I'd also check to see if you have moisture accumulating in the tank/lines
Hell Belcho
There should be no trouble with returning it at all. Call sears corporate if you have trouble. I once returned a 20 year old torque wrench with no problems.
Well, I could run the impact (albeit ineffectively) for a good 15 seconds before the compressor would kick in. If it was going to do something, you'd think 15 seconds would be enough time to spin a lugnut.
Hell Belcho
what HP is your compressor's motor rated at?
Unoffended by naked girls
It's not a compressor problem.
The motor may be gummed up. See if you find some of that air tool oil that smells like wintergreen. Good for loosening the gunk. Or shoot some break-free down the pipe and run it, followed by oil. Unscrew the adjuster all the way out and make sure that passage is clear. Sometimes a peice of machining crud gets left in when they're new...
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
That I'd have to check. Even then, once it's holding 90psi it should be able to spin the thing, no?
There are some little 'hammers' in the motor that have to freely beat theire respective 'anvils'. Run it with a light load for a while and see if it doesn't break loose.
Nothing to lose.
Friend of Warren
Dan is right. Hell I've run my impact wrench off of the compressor I use for my nail gun. It only has a 5 gallon tank. Work just fine in short spurts.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Look under the trigger is there a round adjustment dial? Many guns have an adjustment for power is it possible yours is set at the lowest setting?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Our shop compressor was set to kick off at 125lbs, no doubt some loss by the time it got to the toolthroulg the lines and hose. Tank size shouldn't be the limiting factor, you'll just have to let it catch its breath more often.
Jim
down to jap bikes that run and a dead Norton |
You have to check the requirements for the impact wrench.
In my case I bought a Husky impact wrench that requires 5.1 cfm (cubic feet minute) @ 90 psi to allow the 350-375 ft/lb torque. My compressor is a 4.2 cfm @ 90 so basically it doesn't have the guts to use that impact wrench, I have to break the lug nuts loose then the wrench will do the rest but no way it will ever have the power to undo lug nuts. Actually I'll sell my compressor and buy a new one with enough volume@90psi but I found they're all belt driven. The small ones like mine have the built in pump and motor and at least in Home depot none of those small ones will give the volume @ 90psi. I highly doubt the wrench is gummed because they're oiled in the factory and comes with caps on all ends. -Jasper
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
Jasper
I believe the 5.1 cfm for your wrench is referring to constant/steady usage. Assuming a large enough line is present I would expect a compressor with even a one gallon tank to break loose a lug nut. Jim
Senior Member
Agree with Dave. Put some oil in the air input port and run it on and off for 5 minutes or so. Something is gummed up inside and not working right. 20 gallons is more than enough, and 90 psi is fine for this.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
