Tsk, tsk, YOU should now better! Although, I haven't a clue what the explanation is either! All I know is that in cruise (or flaps up) the outboard ailerons & spoilers are locked, and the inboard ailerons/spoilers work in concert to control roll. The only thing that comes to mind is maybe the AP is compensating for a nasty crosswind (crabbing w/ right aileron + left rudder), and the spoiler is countering the rudder-induced yaw? Still that looks like a lot of deflection for trim. Are you sure you weren't in a gradual right turn? Even the wing vs. horizon in the picture kinda looks that way. Also, since the spoiler is only slightly deflected, another explanation may be that it's cable needs to be re-tensioned and the extreme low pressure on the top side of the wing is "sucking" it up into airstream. Ah, who knows...
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
In flight the wings flex upwards several FEET at the tip, and from the cabin, they appear as depicted in the photo. No crosswind, COURSE and HEADING are the same. Crosswind makes HEADING diverge from COURSE in the direction that the crosswind is coming from. Autopilot doesn't care. It ROLLS A/C to new HEADING to maintain COURSE, and then levels wings again to keep zero error on COURSE. |
Once again, this is probably a mis-rigged board, powered up out of stow slightly, making the aileron compensate. We know from the report that the opposite wing had no such deflections of either kind. |
Light,Nimble,Uncivilized
Drago '69 Coupe R #464 |
Wow, guys. You're coming up with some pretty far reaching explanations. They are fun to read though. Fingpilot has it right as far as I can tell. He knows what he's talking about, obviously. The inboard spoiler panel is up slightly and shouldn't be (could be for any number of reasons, but for the purposes of this discussion it doesn't matter why). This induces a slight rolling tendency left wing down. The autopilot senses this rolling tendency and corrects it with an aileron deflection. Equilibrium is achieved and the autopilot is "happy". However, this does lead to a little more drag and would therefore decrease the range somewhat due to the fact that the autothrust system is set to hold a fixed mach number and would obviously need to counter the slight additional drag with slightly more thrust.
On a side note, are fingpilot and singpilot one and the same? Hmm.
Kantry Member
"On a side note, are fingpilot and singpilot one and the same? Hmm."
I've been thinking of Singpilot as "Singapore Pilot", I think of "fingpilot" as "F___ing Pilot" I could be wrong. ![]() And yes, I too enjoy the 'techie' aspects of the question. (I am neither a pilot, nor flight systems engineer, nor do I play either on TV. I did not stay at a Holiday Inn, last night.) I just like gadgets. Les
Best Les My train of thought has been replaced by a bumper car. |
Senior Member
-- Chief Architect and Mastermind, SCWDP |
1.367m later
(Note to self upon entering "pilot witness protection plan" pick a name that doesn't rhyme with your original name.)
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Well, as long as the otto pilot is happy....
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Bad spoiler actuator causing the spoiler to "float".
1978 911SC #737 "D" Class Club Racer |
typical fingpilot......they know everything
1.367m later
Sure, but speaking for those of us on the ground with the wrenches in our hands it's just another know-it-all button pusher telling us how to do our jobs.
Ah... now the true colors come out.
Clearly, this is a maintenance FUCUP and there are pics to prove it. Dollars to donuts the maint reply to this writeup will be.... "Could not duplicate on ground", and the plane will cross three more oceans like this. |
This thread delivers!
Modes of Transportation: 1984 Porsche 911 Targa 2003 VW Jetta GLI |
"Could not duplicate." How many times have I seen that in 15 years as an airline pilot.
I once had a pilot write up an ADF problem in the tech log thus---
"No 2 ADF off"----I had spoken with him after the days flying and he didnt mention it. So I wrote it up as-- Re No2 ADF off--is it switched off, off heading, or does it just smell bad? S---t hit the fan and I got hauled on the mat over it. No sense of humour those flyboys ,ever since Captain Wilbur declared Orville as the dirty fingernail brigade! |
