Honda Snowblower Help - Solved - Thank You
Picked up a honda snowblower from my neighbor.
It ran for a few minutes, then cut off like it wasn't getting fuel. The gas might be old but wouldn't think this would cause it to just cut off completely.
Any thoughts? It has a gas on/off switch which is in the on position. I can't seem to figure it out before tearing it apart. I don't have a service manual so hard for to tell. Any one have any experience with them?
Did I mention that we are getting two feet of snow right now.
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 12-20-2006, 12:42 PM
is this thing on?
NICKG's Avatar
are you sure it is flowing gas? sounds like the fuel is off....
"People willing to trade their freedom for temporary security deserve neither and will lose both"
~Benjamin Franklin
Old 12-20-2006, 01:20 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Can you remove the float bowl?
It doesn't take much gum to plug up the needle.
Usually the needle gets stuck in the seat.
You would have burned the little bit left in the bowl. but with the needle stuck, no more will flow to replace it...
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 12-20-2006, 01:30 PM
Thanks for the advice. I'll start pulling that off and take a look. Would cold weather effect it. When I changed the oil in it, it ran without a problem. NOw that it's cold, no gas.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 12-20-2006, 01:57 PM
dhoward's Avatar
Others may recommend against this, but for my snowblower, I keep a can of ether and give it a quick shot if it's finnickey. Of course mine gets used every 4 years...
Dan
1969 911T (sold)
2008 FXDL
Old 12-20-2006, 02:03 PM
Registered ConfUser
Oops. I thought this was the Miss America thread.
Never mind.
Mike
Old 12-20-2006, 04:31 PM
Well, it definitely has something to do with the float bowl. When I remove, the gas comes right out the little nozzle. Seems to be working fine now.
Is the thought that something keeps clogging it up? Or, is the float defective. Never dealt with small engines so I'm learning as I go.
Lost the pull cord now (frayed off) so I have to get a new cord.
Michael
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 12-20-2006, 04:42 PM
dhoward's Avatar
If fuel flows when the float drops (I'm assuming it hangs when installed) and stops when you push it up against the seat, then it's working properly. Small engines are no different than large engines, there's just less 'stuff'...
It really doesn't take much crud or sludge to stop the flow.
I used to keep a 10mm wrench in my car when I first got it running to clean the idle jets every 15 miles or so....
Dan
1969 911T (sold)
2008 FXDL
Old 12-20-2006, 04:53 PM
Once again, thank you for all your help.
Once I pulled the float bowl, and really cleaned out the port with carb cleaner, it started working. Poured some carb cleaner in with new gas and it's running like a champ.
We aren't quite dug out from the last snowstorm and the next one is on it's way. Their predicting only 18 inches, which is a lot less than the 30 we just got.
Wouldn't trade living in Denver for anywhere though.
Michael
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 12-28-2006, 09:19 AM
dhoward's Avatar
Glad to try to help.
Good luck!
Dan
1969 911T (sold)
2008 FXDL
Old 12-28-2006, 09:24 AM
