-   -   Installing Slate Floor Tile (http://forums.pelicanparts.com/off-topic-discussions/322462-installing-slate-floor-tile.html)
trekkor 01-02-2007 05:09 PM
Originally posted by dmoolenaar
KT, have you ever used a crack isolation product called Red Guard? Any insider info on it's performance vs. a traditional crack isolation layer sold in many tile stores?
I've seen it used. I have stayed away from it. One part membranes worry me. that's just me. ( Ultraset is an exception )
I like Mapei PRP-315 for crack isolation. As a true moisture barrior, I'm sold on sheet vinyl.
The peel and stick over a primered surface seems to be the best solution. ( Esp. on a fresh slab with cracks )
The thing with Custom's "Red Guard", is DYI'ers are lulled into thinking this is an exceptable pan liner. I reject advice from the Home Depot staff.
KT
trekkor 01-02-2007 05:21 PM
I'd also suggest breaking the application into small sections, 2'x2', at a time. If you let the sealer dry to a white haze you've waited too long and it's darn near impossible to buff clean. The solution is to apply more sealer over the haze and then buff. Definitely go for a respirator or minimum a big room fan. You can expect the kitchen to smell like sealer for a day or two afterward. Not easy but the stuff really works.
Wise words...
KT
SLO-BOB 01-02-2007 05:38 PM
Originally posted by Moneyguy1
Trying to imagine a close to full size sedan parked in the middle of a kitchen.......
Actually, try to imagine that sedan melted down into a 1/4 inch deep puddle evenly distributed all over the floor. :)
On rental saws- Look around for a good one otherwise you will be sad. I got a nearly new, unsure of make, tile saw that worked perfectly. I unfortunately had to do some diagonal cuts on my 16 inch tile where it met a transition to the kitchen at an angle. Not a problem with the right saw, but sometimes slate doesn't like pointy ends so beware. Anything other than a good wet saw will be a nightmare.
On screws and Hardibacker - I pre-drilled with a 1/8th masonary bit. Made it a lot easier but you have to use strong screws to sink them in. The heads will snap off of cheapies. Installing the Hardibacker over thinset sounds like a pita and a mess. I'm sure it's the best way to go but I'de have a hard time psyching myself up for that one. My old kitchen was done with screws and never a creak or crack after 5 years.
rcecale 01-02-2007 05:53 PM
Keep the ideas coming, fellas! This is great!!!
Okay, been doing some thinking about this job today and have come up with a few questions.
1. How clean does the HardieBacker need to be when I'm applying the thinset and tiles? Will a sweep & vacuum just prior to laying the thinset be good enough?
Obviously I'm not going to finish this job in a day, so, once I have the HardieBack down, we'll be forced to walk on it some just through our day to day living. We've got a lot of rugs and mats that I can lay out for the heavy traffic areas, and such, but are there any other considerations I need to be concerned with.
2. How will the HardieBacker stand up to the traffic until I get it covered with the slate?
It's just my wife and I, and our two Shih Tzus, so it's not like we'll be tracking in mud from the playground or anything like that. (Although, I imagine I'll be doing some yard work as time goes by...but I've promised my wife to take off my shoes before coming into the house... :) )
3. Speaking of our Shih Tzus, how "traqic" will it be if one of them has an accident on the HardieBoard? Simple clean-up with bleach, maybe some vinegar?
(This question applies to the slate floor as well.)
They're home alone all day, kept in an area where the floor is the existing linoleum, and are usually pretty good. We leave training pads out for them during the day, just in case, because the days can occasionally get a little long.
Randy
CarreraDan 01-02-2007 06:43 PM
Randy,
To answer your questions, use a shop vac before laying the thinset, then shop vac the Hardibacker before laying the tile. I have never had a problem with traffic on Hardibacker, just don't roll anything really heavy onto the edge--walking on it shouldn't be a problem--you can crush it. As for the dogs, the Hardibacker will not break down under water--again it shouldn't be a problem. When you get your slate down I would seal it if you are worried about the dogs. Another thing to check out is Home Depot's stainproof grout. It is a pain to use but you cannot stain it--I have tried everything I can think of including brake fluid, oil, etc--it will not stain. I always use thinset (Flexbond) under the Hardibacker, then use Hardi's screws--my clients are paying for a professional job so why not do it the right way--and afterall it is only 56 screws per sheet, not that I have ever counted or anything. If you work one sheet at a time it really isn't that bad, I always precut and test fit my Hardibacker before I start laying it with the thinset and screws.
KT, Redgaurd is a very good product if you follow the directions and use it like Custom recommends. For an experiment we took a shoebox and sealed it with Redgaurd, then filled it with water. After two weeks it didn't leak and I was tired of refilling it so I gave up. Personally, I don't use it but it does work and a few friends have been happy with it.
One last thing for anyone looking for good flooring advice is to ask around at the home improvement stores in other departments for who is the best. I was trained by three flooring masters at Home Depot who had over 110 yrs combined experience with flooring. Granted none of us any longer work there but that is a different story. If anyone has any questions feel free to PM me.
trekkor 01-02-2007 06:53 PM
Remember, no twenty year warranty from James Hardie unless you do it.
Use nails...Screws hurl.
KT
turbo6bar 01-02-2007 07:34 PM
800 SF. Wow, you're gonna hurt after that job. ;) I recommend a hot tub and/or heating pad to repair your body each evening. You'll be pleased with the end result, though.
Agree on the thinset under Hardibacker. Tile and stone is good for a lifetime. Why compromise on the install?
I use screws, but the roofing nailer sounds like the hot setup.
KT, the local tile place has a Rubi bridge tile saw on closeout for $990. Do you believe there is any benefit to the bridge saw vs the typical tile saw with sliding tray? I would like to upgrade and am comparing the slew of different saws.
BTW, I prefer using metric tape measures when laying tile. It's a lot easier when measuring for cuts and also when laying the grid. I have no idea what the pros do, but it works for my brother and I.
jurgen
rcecale 01-02-2007 09:34 PM
Found this saw at Harbor Freight. At $199, the price is certainly right. Anyone have any experience with Chicago Electric Tools?
http://forums.pelicanparts.com/uploa...1167802400.gif
Here's the link to the source:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92386
Randy
trekkor 01-02-2007 10:35 PM
The roofing nail gun is fantastic.
I can install 400 square feet by myself in one day. Done it many times.
120 nails in a coil. It takes 88 nails on a sheet of backer.
I chase all the high nails and set a nail next to every nail that went too deep with hand nails.
Fiber glass tape all the joints with acrylic modified thinset using a flat trowell. ( plastering trowell ).
On the bridge saws... Unless you are planning on 24" tiles or bigger, I don't know why you would need this saw.
Randy, the harbor freight saw might be a good bargin for this one job.
I would NEVER use anything from them for day-in, day-out use.
I'm a fan of MK.
I have the 770, 101 and 1070 as well as a handheld circular saw.
Diamond blade on a grinder has it's place. Very messy.
Wear ear plugs, fellas. ;)
KT
rcecale 01-03-2007 03:12 AM
I'm a fan of MK.
KT
Mainly what I'm looking at (at this point) is price and diagonal cut capacity...not necessarily in that order.
I've looked at a few Felkers (The Felker F-75 is mentioned a lot of places as a great saw) but the ones I find are either too "underpowered" (comparatively), or they aren't able to cut a 16" tile diagonally. The saws that seem to have that capacity are up closer to the $1000.00 range. I was hoping to get by with maybe $500.00...certainly no more than $600.
The MK 770 is too small, though priced in my range. Of the three MK-101 models I found, only the MK-101Pro 24 will cut a 16" tile diagonally...at $1299, it's definitely out of my range. The MK 1070 certainly seems up to the task, with cutting capacity and it's 2 HP motor, it seems it would make short work of all my cutting needs, but again, at $1300, it's out of my range.
I just figured with the Chicago saw above, at the price, if I happened to wear it out, I could still get a totally new unit and still be withing the $500 range...even a third would be right at $600. Disposable saws? What a concept? ;) It also has a 1.5 HP motor.
Keep the info coming though. I really am paying close attention to what everyone is saying.
Regards,
Randy
turbo6bar 01-03-2007 06:10 AM
Randy, I bought the Chicago Electric with sliding tray (not the bridge saw you have pictured) and am still using it today. My brother and I have laid down several thousand square feet (lost count a long time ago) using that junker saw, and it has served well. In my opinion, you're not going to break that saw, but you probably will wear out the blade in no time. I haven't cut slate before, so maybe the blade will be fine.
regards,
jurgen
RickM 01-03-2007 07:54 AM
I read most of this post and didn't see any reference to existing floor removal and potential asbestos exposure. You may want to take precautions. I just finished a 400 sf kitchen floor removal and replacement. I tented the entire area, wore a good respirator/filter and tyvek hooded coveralls, used a water/soap mixture to wet down all potentially contaminated flooring materials to be removed and bagged very carefully.
"Flooring materials including:
* 9 inch by 9 inch floor tile (older, thicker floor tile)
* 12 inch by 12 inch floor tile (commonly used today)
* Sheet linoleum
* Mastic (glue located under the floor tile or linoleum)
There have been many instances where a homeowner decides to restore the natural wood floors in his/her home. In order to do this, the current flooring (floor tile or linoleum) must first be removed along with the glue underneath. The best way to get a smooth finish is to sand the glue off the wood. However, if there is asbestos in the glue, sanding it will cause the asbestos to become airborne, thus contaminating the entire house."
fastpat 01-03-2007 08:22 AM
Randy
That saw looks like the deal, but it pulls 24 amps at startup, so says the web site, and that's going to be an issue on a 20 amp circuit. You may have to install a special circuit, 120v 30 amp individual circuits aren't common in most homes.
rcecale 01-03-2007 03:33 PM
Good eye, Pat, thanks!
Okay, it's now looking like this QEP 83200 is going to be the one. They carry it at Northern Tool, which is located only a few miles from home, so I can save on shipping charges.
I've read a little about QEP, and although they aren't the same caliber as an MK, a Felker or a Target, it seems as though it should be up to the task..
And at 9.2 amps, I shouldn't have to make any changes or additions to myhome electrical system. One project at a time, thanks! :D
http://forums.pelicanparts.com/uploa...1167867149.jpg
Randy
porsche930dude 01-03-2007 03:33 PM
If theres one thing iv learned about tile. Its that you can never have too much mortar. Especially on 12" or bigger tile. so get the biggest tooth trowel you can and go to town :)
trekkor 01-03-2007 07:52 PM
Finally!! Yes!!
The biggest mistake do-it-yourselfers make, is using too small of a trowell. Just last night on one of these home improvement type shows, they were using a 1/4"x1/4" square notched trowell, combing it on the back of the 18x18 travertine tiles and then setting it over radiant heat netting/element. I wanted to scream.
I use a 1/2"x1/2" on 12" or bigger flat back floor tile.
The saltillo clay floor tiles I'm currently finishing up get the 3/4" round notched trowell as well as "back-buttering" them flat with a 18" swimming pool trowel.
I get about 40 square feet per 50# sack of thinset.
It is a 1000 square foot job.
Do it once!!
KT
trekkor 01-03-2007 08:00 PM
Oh and aside from Saltillos, slate may be the dirtiest tile to work with.
Think, petrified dirt ;)
I use a "water proof" booth. I place the saw stand in a large plastic tub and make a three sided frame wrapped in clear plastic.
Total containment. I will sometimes protect the floor and work indoors.
Maybe I sholud take I picture of my booth before I break the saw down tomorrow.
KT
rcecale 01-03-2007 08:12 PM
KT
Please do! :) Pics are always helpful!
My thoughts are, with a wet saw, there isn't a lot of dust, but rather spattered "mud" being sprayed around by the spinning saw blade?
Randy
SLO-BOB 01-03-2007 08:19 PM
Amen! I cut everything outside. I also washed every tile before bringing it in. It was unbelievably messy and my driveway still is discolored just from the wash.
I learned the hard way that "back buttering" is a very good idea. My first attempt, which excluded that step, was a dismal failure. About half the tiles came loose upon drying. I'm sure the other half would have followed soon. Fortunately, I just got started before taking a break and only a few tiles needed to be redone.
I'm not sure if this is good, bad, or makes no difference, but I washed the tiles just before installing them. I back buttered them (using the smooth trowel) while they were damp, not wet. My reasoning was the thinset would stick better.
PS- I would just rent a saw. It's cheap, you'll likely get a better quality tool, and you won't have to store it when you're done. Plus, Chicago tools are hit and miss.
BertBeagle 01-03-2007 08:46 PM
If anyone is looking to buy a nice wet tile saw I have this one for sale. I can band to a pallet and ship it from my shop. It has a 14" blade and sliding table. This is a very nice professional saw with a Baldor motor.
Link to more info
http://www.mytoolstore.com/target/mason02.html
It was used for one job, cutting pavers to make planted areas in a large yard.
I will sell for a fair price or trade for something else.
http://forums.pelicanparts.com/uploa...1167885950.jpg
