Composite Construction Question - Airplane Guys
The question appies to hovercraft, but the concept is the same to airplanes (I think). Help answer this guys question.
Link: http://www.hoverclubofamerica.org/forum/index.php?showtopic=1018 Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Senior Member
The addition of any additional fiber should stiffen the assy up. As long as not too much fiber (weight) is added it should not be an issue.
One problem is that carbon fiber is expensive so you do not want to just start spreading it around everywhere. Might want to get Thom (widebody911) in on this thread as he has a lot more carbon fiber experience than most on this bulletin board.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Banned
Re: Composite Construction Question - Airplane Guys
He doesn't give enough information about the part he is designing. I don't know why he is using multiple layers of foam, nor whether the part is flat, or has curvature. etc.
In general, the strength of the composite structure comes from the outermost layers; the "skin," if you will. The core material mainly serves to keep the outer layers a certain distance apart. There may be little or no stress and strain near the center of a composite strucure. In such a case, adding a layer of carbon cloth would be a waste of material. Not knowing any more about what he is trying to accomplish, I'd say no. JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
MAGA
Carbon fiber can be bought in bi-directional cloth which posseses strength in both directions, or can be purchased in unidirectional tapes or tow that consist of strands all run the same direction to provide high tensile strength. Same goes for Kevlar and fiberglass.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Sounds like he took some sketchy notes, and couldn't remember all the details.
He is talking about using Graphite unidirectional tape in a V configuration, and also mentions impregnated fibers, we call it prepreg for short, with the correct amount of resin for saturation. Javadog is right. make it with two layers of carbon in a V, both sides of the skin, and foam core in the center.
72 914 2056: 74 9146 2.2: 76 914 2.0 |
You guys are right about a middle layer typically not being used because the top layer is in compression and bottom layer in tension............as a general rule. I think this why the suggestion of a middle layer of CF has raised the question in the first place.
I should note that there is a composite replacement for marine plywood which will hold a screw as the exception. Coosa http://www.coosacomposites.com/ Quote:
