Free minder
Aurel's Avatar
Question for IT geeks
Is there a MS-DOS instruction that gives a listing of the IP adresses of all computers in a LAN network? Something similar to ipconfig, but for all the PCs my PC can see on the LAN? TIA
Aurel
Old 01-04-2007, 06:42 AM
mikester's Avatar
Send a message via AIM to mikester
No, not really - you would need to get an external program to really do that.
You can try arp -a which will show all the arp entries you computer knows about but that will only show things on the local subnet your computer is actually talking too.
You can also do a netstat -an which will show any established connections to your computer.
Lastly you can do a ping to the network broadcast address but that address depends on the size of the subnet on your network.
For example is your network is 192.168.100.0 with a netmask of 255.255.255.0 the broadcast address is 192.168.100.255.
if you ping that address then all hosts on that network will answer, if you're using Linux/UNIX you'll need to add a -b to the end of the command. Most routers won't allow this sort of ping to occur.
Your best bet is to use an IP scanner like this one:
http://www.angryziber.com/ipscan/
-The Mikester
I heart Boobies
Old 01-04-2007, 07:03 AM
Ip sniffer will do this. It's not a Dos command but it'll do:
http://www.snapfiles.com/get/ipsniffer.html
Old 01-04-2007, 07:04 AM
Free minder
Aurel's Avatar
Thanks!
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 01-04-2007, 07:23 AM
You can ping 224.0.0.1 and then arp -a.
224.0.0.1 is a special multicast address that requestes that all hosts on a network reply. And then with the arp -a you should see a list. You should actually be able to see the hosts as they reply so the arp -a is not 100% necessary. This may not work for PCs that have Windows XP firewall enabled.
Here's a sample of what you'd get.
H:\>ping 224.0.0.1
Pinging 224.0.0.1 with 32 bytes of data:
Reply from 10.20.166.254: bytes=32 time<1ms TTL=255
Reply from 10.20.166.118: bytes=32 time<1ms TTL=64
Ping statistics for 224.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
H:\>arp -a
Interface: 10.20.166.49 --- 0x10003
Internet Address Physical Address Type
10.20.166.102 00-0e-7f-e7-c1-63 dynamic
10.20.166.118 00-13-21-26-61-33 dynamic
10.20.166.254 00-0d-ed-c0-08-43 dynamic
Old 01-04-2007, 07:25 AM
mikester's Avatar
Oiy!
That's a much better answer, I concede defeat.
-The Mikester
I heart Boobies
Old 01-04-2007, 07:26 AM
if you want a good windows scanner, superscan is a pretty good one as well.
http://www.foundstone.com/index.htm?subnav=resources/navigation.htm&subcontent=/resources/proddesc/superscan.htm
Old 01-04-2007, 07:27 AM
Very cool. Thanks!
Old 01-04-2007, 07:52 AM
19 years and 17k posts...
azasadny's Avatar
You can download a good scanner from GFI LanGuard that won't cost you anything for a 30 day trial. It will tell you more than you want to know...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 01-04-2007, 07:54 AM
Free minder
Aurel's Avatar
Exactly what I was thinking about. You are the Geekmaster! Thanks.
Aurel
Old 01-04-2007, 08:01 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
224.0.0.1 produced some interesting results on my end. I get about 4-5 of the 100+ machines on my subnet to reply, even though I can manually ping machines that don't reply to the 244.0.0.1 ping. What I did in this situation was to create a batch file to ping each machine in the subnet then check to see if there was a resulting arp table entry
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-04-2007, 08:07 AM
VincentVega's Avatar
You need to make sure your routers are forwarding multicast for that to work. On a simple flat network it should work fine. If you are using dhcp you should have a report on the server.
Old 01-04-2007, 08:16 AM
Senior Member
Good info!
Old 01-04-2007, 08:34 AM
id10t's Avatar
With DHCP on the LAN, just check your leases file. Otherwise, use something fun like nmap to search for active machines on your subnet.
Old 01-04-2007, 08:42 AM
Halm's Avatar
From a CMD prompt: net view
'17 Cayenne
Old 01-04-2007, 09:44 AM
